Powder Coat wheels in Los Angeles?
Old 10-15-2010 | 02:47 PM
Fastforwardwheels's Avatar
Fastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to beholdFastforwardwheels is a splendid one to behold
here is some food for the mind...
Here is our process when we refinish your wheels
* First your wheels gets checked for small imperfections such as curb-rash, bends and cracks, we use a hydraulic press designed only for repair rims to make our corrections.
* Second your wheels gets repaired such as welding, aluminum fill and resurfacing.
* Third your wheel get prepared for paint, we strip the wheel down in order to have a good surface to perform the first paint layer.
* Fourth your wheels are dipped in our Hot-Ultra-Sonic tank which is a similar to those used to clean your jewelry only MUCH bigger.
* Fifth we then have your wheels pulled out of the Hot tank to a cold water bath.
* Sixth we remove your wheels from the cold water bath and give them a high pressure blast to ensure all of the water from the Hot and Cold tanks are removed completely.
* Seventh your wheels are then prepared for painting, here certain areas will be masked.
* Eighth your wheels will receive their color coat of choice, this first layer is in a flat to better absorb into the aluminum while acting as a primer coating.
* Ninth your wheels are then clear coated either in Flat, Semi-Gloss or High-Gloss.
* Tenth your wheels are touched up from masking and such.
* Eleventh your wheels are allowed to cure in a dry room so that the paint may take its time to cure on it's own before the baking process begins.
* Twelfth your wheels are baked in our bakers, we cannot disclose as to the temperatures or times we use as this is a trade secret but we will ensure you that the process is near nowhere close to the heat others use when they use in powder coating treatment.
* At this point your wheels only need to cure which takes around 12-24 hours more before you're safe to mount your tires.
Old 10-15-2010 | 05:03 PM
07997's Avatar
07997 is infamous around these parts
Andrews Powder Coating
9801 Independence Ave.
Chatsworth, CA 91311
(818) 700-1030
www.powdercoater.com
Old 10-15-2010 | 05:54 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Good looking wheels
Old 10-23-2010 | 03:00 AM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
During forging the wheels are heated and cooled down twice in order to make them strong. Now why would anyone want to weaken their wheels on pourpose? To save a couple of dollars? OK, then...
(818) 700-1030
Old 02-09-2023 | 07:35 PM
Meprathe's Avatar
Meprathe is infamous around these parts
Check out these guys $600 bucks and next day service! Great little local shop in downtown LA powder coating rims LA
midwesterner
Midwest
11-19-2014 12:53 PM
964speed
964
08-04-2009 11:02 AM
dawk
Colorado
11-10-2008 09:52 AM
Kingshawn1234
Cayenne 955/957
11-04-2008 06:07 PM
BlackBear
02-27-2008 02:14 PM
Quick Reply: Powder Coat wheels in Los Angeles?
