Protomotive Full install in the UK
#62
That is why I was asking what others do, because I was surprised at the time from a second gear launch.
I will try a first gear start to see the times and if there is a difference.
#63
Thanks for that. I presume from the drop in g that this is a manual because that is a long time to shift,but even then a quick time. My time from 60-100 was 3.12, so I must when I get a chance find time to do a 60-130.
Here is my 60-100 including a shift from 2nd to 3rd gear. Look at the difference in the shift time compared to the original image. I think my tip is shifting well.
#64
#65
ttboost,
Yep I am running the 20s. But it is on a tiptronic, so maybe I am losing some power to the wheels compared with a manual - not sure.
I was expecting around 2.6 or so from 60-100 as well. I am running full weight as well, nothing removed etc. I am running pump fuel in the UK (99 so that is around 95US). Todd K has done the second map for me and that is improved the response as the car was running a little rich.
For that 2.6 that you done: -
1) Did you have PSM off?
2) What speed did you start at?
3) What fuel were you running?
4) What boost levels did you have on the 18g?
Like I said I have run the car at 70% boost of WG, so that would be around 1.36bar. Probably need to crank it up a bit, but might need better fuel.
Ken
Ken
#66
ttboost,
1) Did you have PSM off? Absolutely turn it off!!!
2) What speed did you start at? 30-35mph
3) What fuel were you running? 93oct pump with 100% meth
4) What boost levels did you have on the 18g? 1.3bar
Ken
Ken
WheelB
Lamborghini
08-20-2015 12:25 PM
Nissan GTR
08-19-2015 02:11 PM
