blow off valve springs?
Has anybody needed to install stronger springs on there BOVs? When I get on the freeway accelerating in second gear (nornal to a little fast) I can hear the BOVs opening, is this normal? Alpha 30/76 turbos BOVs mounted on the intercoolers, Proto intake. I asked Todd and he said I should not need to change the springs.
I got the green and the yellow springs with my Forge DVs
I can't remember the spring rating of them but i'm using the uprated yellow ones
Are you sure it's the DVs you're hearing?
This is a very old school (original 930) way to increase HP (it stiffer springs in the waste gates). Not very refined. It works but your better off approaching this as a complete system: ECU, DV, intake, exhaust, and bypass values tuned to work together with adequate safety margins for your engine.
2001 996TT 3.6L and stock ECU
springs
Mark, I have the bovs that Todd sent me with the complete intake kit, and of course your snazzy intercoolers.
Then your def. fine.... they make noise as you let off....
Bov
Mark, they are opening while I am accelerating, must be making more boost than the engine wants.
Did yo take out the stock DV solenoid?
they aren't opening, its the turbos going into surge....is this in say 6th gear when you pull out to pass someone at low RPM?
DV's
Mark, the system was pressure checked no leaks. yes the stock dv solenoid was removed.
Taxthe1%
09-10-2015 09:33 AM
arhim22
09-07-2015 08:49 PM
