There is a very loose piece of "heat shield/metal" between the exhaust
Old 03-17-2010 | 09:42 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
tips and the rear bumper. I can slide it around easily, is this normal? I dont here it when csr is runnig parked or otherwise?
Old 03-17-2010 | 09:51 AM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
I think I have the same issue. It rattles like hell when I shut the passanger side door (that is the side that is lose). I use to think it was something in the engine compartment - its not. Mine is just to the right of the right exhaust tips.
Having it looked at next week.
Old 03-17-2010 | 10:07 AM
fdorn's Avatar
Here is a pic:
Old 03-17-2010 | 10:22 AM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
As I recall - when I was replacing the plugs / coils I had to move the heat shield a little bit out of the way. It was held in place by some bolts. Maybe you've lost the retaining bolts ??
Old 03-17-2010 | 10:33 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Is it the 'foil' or metal heatshield you're referring to?
I posted a similar question a little while ago and someone gave me a -1 rep and called me a moron!.....I couldn't believe it, I've said far more stupid things than that previously!
Old 03-17-2010 | 10:37 AM
timf's Avatar
I'm referring to a flexible metalized foil I had to pull back then re-secure. It wasn't a proper metal plate heat shield. It was the material shown in the picture above.
Old 03-17-2010 | 10:44 AM
ant_8u's Avatar
I had the metal shield which runs across the width of the exhaust come loose on mine
The metal shield is held in place by 6-8 self taping screws and is a nightmare to secure again with the exhaust still in place
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
alevine
11-04-2015 10:05 AM
gulf gt
08-27-2015 10:27 AM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
HolmaN
08-18-2015 01:35 PM
Quick Reply: There is a very loose piece of "heat shield/metal" between the exhaust
