Vacuum pump
Old 03-20-2010 | 10:19 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Vacuum pump
while adjusting the wastegates using a vacuum pump ,are you pressurizing or applying vacuum to the waste gates?thank you.
Old 03-20-2010 | 11:47 AM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
If you are using a vacuum pump you would be applying vacuum.
Old 03-20-2010 | 07:42 PM
BLKMGK's Avatar
To adjust the W/G use PRESSURE. W/G only trigger under pressure so to adjust when they begin to active that's what you want. Use a handpump that can pressurize or an air supply that's metered WAY down.
Old 03-21-2010 | 02:07 AM
So both ways are correct?applying vacuum or pressure !
Old 03-21-2010 | 07:49 AM
ard's Avatar
ard
NO. First reply is incorrect. Only pressure to activate. Use a T fitting so you can apply the same pressure to both (or apply the pressure before the line T's) that way you can synchronize them.
Old 03-21-2010 | 08:15 AM
How do you use a vacuum pump to apply pressure.It is only applying vacuum.
Old 03-21-2010 | 11:03 AM
Please help,need to know how to do it using a vacuum pump
Old 03-21-2010 | 11:57 AM
ard's Avatar
ard
Simple. YOU DO NOT USE A VACUUM PUMP.
Most little hand held ____ pumps can apply vacuum or pressure, depending on how you hook them up. So when someone says 'just use a handheld vacuum pump to sync them' they really mean pressure pump.
There are a ZILLION posts on adjusting wastegates, here, over on rennlist...
Old 03-21-2010 | 07:31 PM
BLKMGK's Avatar
See this? It can do Vac AND pressure!!!
Old 03-21-2010 | 10:58 PM
Thank you for all the info
adnanm3
10-25-2016 08:38 AM
White991TT
03-08-2016 06:01 AM
panas001
09-27-2015 02:51 PM
Quick Reply: Vacuum pump
