Please post the name of the tuner(s) that modified your car
#181
What are the divisions on your graph Scott?
#182
Scott, isn't that like saying EVOMS (pre-2008), AWE, Champion Motorsport, and GMG should all be listed under GIAC, despite the fact that they do their own fabrication?
#183
Switzer is an installer? They fabricate a large amount of their hardware and bolt ons. Doesn't R&D and fabrication count as a tuner?
I think keeping it separated and putting numbers by each one like BBI*
"* All under this use Protomotive Tune"
would work. Replace asterisk by number for more of the same. That way, they all get their credit, but you can see the common tune between groups.
#184
The graph is too small to see in the post and is very blurry when you click on it to blow it up. ( or at lease it is for me )
Is there any other spread sheet you can use so that it is bigger in the initial post?
#185
Original work by Markski/Bobby, IC's by TPC, ECU by Todd K? There is so much overlap in this community and so few people doing ECU tuning that you are going to see overlap.
bob
#186
911tuning*
* Protomotive based tune.
If you make this too complicated you, then it will be a problem.
#190
It's now a Proto/TPC Racing car.
#192
I do Neil, and I love the thing. But I also have an ATS clutch and B&M shifter. But I'm only asking for the top two companies (see the very first post). Otherwise, it will get even more confusing than it already is.
I'm to the point now where if someone else wants to take it over (ahem *Dennis or Bob*), feel free.
#195
I need to add here that we should not simply be lumped into Protomotive. While early on we worked exclusively with Todd at Proto for our tuning solutions, currently that is not the case. We work with many technology partners to achieve the results that we do, and to tie us to Protomotive for everything that we do would not be a correct or fair assessment.
