Today's E.T/mph at TX2K10
Old 03-24-2010, 11:10 AM
Divexxtreme's Avatar
Originally Posted by Dr_jitsu
You will probably be fine, Scott....it seems these engines can take it. However I am just going by what Todd K told me. I am sure he is being conservative.
Sean - I wasn't there for your's and Todd's conversation, but he has never told me anything like that.
The information I'm about to give you should clear this up once and for all:
-My buddy Peter made 914rwhp in his 3.8 liter TT.
-Marksi's old setup made 870 rwhp.
Guess what injectors both of these cars were using? 60 lbrs. The exact same ones that Eric and I have in our cars.
Considering all of that, it's safe to say that 60lb injectors are good for far more power than you, me, or Eric will probably ever run in our cars...even with engine-builds.
  #77
Old 03-24-2010, 11:37 AM
Yep Scott is right... but I had the -8 lines and parallel pumps vs. the series..
the series pumps with 60lbs. usually are good for upper 700s... then it leans a out a little on top... so just watch ur afrs....
I do not know the results if any but I have a feeing it will be a number...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #78
Old 03-24-2010, 11:49 AM
Right. It's a limitation of the fuel pumps. Not the injectors.
  #79
Old 03-24-2010, 11:52 AM
AtomicZ's Avatar
AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !
Originally Posted by OhioGT2
Eric,
So how much are you loving that GT2 now! A three year old Proto kit turned up a bit really put the smack down on Sunday!
Now sell one of your Prowlers - you do realize they are never going to be a collector car don't you? - and call Tym or BL. You already arguably own the nicest and cleanest GT2 in the United States...and it is one check away from trapping 150+ all day long.
Great seeing you again. Good luck at the Mile!
Jamie - I absolutely love the car. It is amazing. I have talked to Todd K briefly about what I need to run more boost safely. The Prowler is unofficially for sale - I was supposed to sell it and the '69 442 coupe to buy the GT2. Somehow it just never happened.
Originally Posted by Neil Switzer
Great job again Chris!!
You still running our exhaust and modded off road pipes?
Eric, you have my number... 150+ traps are calling you...
Neil - Yes it still has your exhaust with cats. Sounds great.
Originally Posted by PALETTE
Congrats Eric, I dont see why you need to change anything, Your car is running really strong. Get the boost turned up a bit more and i am sure you will be there. Proto build a great package for the car then 3 years ago and its still a monster everyone else is just now catching up. BTW what boost were you running?
It is amazing to say the least that Todd K built the car over three years ago and it had not been ran on high boost for almost two years until about 15 minutes before we dyno'd it. Running 1.5-1.55 bar.
Proto/Switzer/Evoms/Boost Logic are doing amazing things now but this car still holds it own.
Originally Posted by Divexxtreme
I think there's one GT2 ahead of it, but I'm a bit biased...
Scott/Sean/Paulie - I hate to burst all of your bubbles but LuisGT2's '04 Gaurds Red GT2 here in Minneapolis has only about 3k miles on it and is just plain SICK. It is as clean as the day it rolled of the assembly line.
  #80
Old 03-24-2010, 11:57 AM
AtomicZ's Avatar
Originally Posted by houstonT
Eric, your GT2 is SICK! I did NOT get a chance to drive her at TX2K10....so you know what that means this coming TX Mile weekend, right?
Peter
Peter -
No worries. I know TX2K10 is such a busy weekend for you. We'll work something out at the mile.
  #81
Old 03-24-2010, 12:18 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Hey, you behave yourself up there!!
I told you in another thread any hasty decisions will almost certainly cost me money as well!
  #82
Old 03-24-2010, 12:21 PM
AtomicZ's Avatar
I don't have a 200mph slip - you do.
There will be no major mods to the car this year. It is running very well and I am still getting used to it and a Porsche in general.
  #83
Old 03-24-2010, 12:27 PM
bmoores's Avatar
You will blow by the 200mph mark! My car has a freakish top end but yours is no doubt stronger.
  #84
Old 03-24-2010, 01:43 PM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Yikes... upper 700's with 60lb injectors??
  #85
Old 03-24-2010, 01:44 PM
Tony@epl's Avatar
No, he doesn't. The injectors he has in his car are good for 1.8+ BAR at 800+ rwhp.
My car is running the same injectors (I actually installed 83 lbrs, but went back to the 60lbrs), and TPC will be cranking up the boost today.
Why did you take the 83's out?
  #86
Old 03-24-2010, 01:45 PM
Actually, 914.
  #87
Old 03-24-2010, 01:46 PM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
For those of you running 60's, what is your line pressure behind them?
  #88
Old 03-24-2010, 01:48 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Do you all use Vortech FMU's on your setups?
  #89
Tony@epl's Avatar
Actually, 914.
If Jesus Christ himself was running the dyno while the holy ghost was tuning, I wouldnt run 60lb injectors to 900+ .
  #90
Old 03-24-2010, 01:51 PM
Powell's Avatar
Check the engine bay for one of these bad boys!
Quick Reply: Today's E.T/mph at TX2K10
