Help... Car will not start ! Only CLICK
Hi There,
I need some help. My 2004 994 TT Cab refuse to start for absolutely no reasons. I thought it was the battery so I bought a brand new one and had it fully charged/installed. When I turn the key to start, I hear a single "CLICK", coming from under the car, but not CLICK CLICK CLICK (like it does when low batt).... That Single click I hear is definitevely coming from the starter. Then, a message in the dash says "Error, check BAttery/Alternator"...
LAst week, we removed the engine to change the clutch, but I was able to start the car about 3 times since then (100miles)... (btw, I did press the clutch and the clutch switch is working properly)
Anyone know what can be my problem ?
Right side(pass side frame rail) by the coil packs I think its a 13mm that holds it. only reason I say this, is because you said you just had the motor out.
PorscheEnthusiast
11-13-2015 03:23 PM
ECS Tuning - VW
08-20-2015 04:07 PM
Yotam Refael
Cayenne
08-18-2015 04:03 PM
