stock ride quality versus PSS/KW kits
Old 04-15-2010, 04:19 AM
eds966tt's Avatar
eds966tt is infamous around these parts
Thanks maybe Tom of Rennsport can confirm. Tom it does not make sense to use a setup that is not progressive and depends on the shock. Can you please confirm. I found HR the best for the track at any speed... seems coilovers are street only with less performance when compared to a track Spring like HR. your thoughts?
  #32
Old 04-22-2010, 07:43 PM
eds966tt's Avatar
It seems KW meets my setup as well however I want t replace he upper mounts as well. What do you guys suggest?
  #33
Old 04-23-2010, 09:01 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Originally Posted by Duane996tt
I believe KW use progressives on the front with fixed rate on the rear with helper springs. Bilstein uses helper springs at all 4 corners with fixed rate springs
That's correct. KW uses a progressive rate front spring with a 630lb linear spring in the rear on the 996 turbo application. Bilstein (I believe) uses fixed rate at all four corners.
Keep in mind, too, that KW I believe is the only company that uses a multi-million dollar 4-post chasis shaker rig to test and determine the optimal spring rates for each of their applications.
  #34
Old 04-23-2010, 09:04 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
if you are planning on using pss9's read this thread and make sure you let your mechanic know that he must re-use these parts or you will have creaking and twanging in the front
http://forums.rennlist.com/rennforum...end-noise.html
  #35
Old 04-23-2010, 09:22 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Srock suspension isn't that good,i haven't change mine so far but i like it better KW.It is ease to tune because the **** are up and the Bilstein you have to lay on the floor to turn the ****.At the track the KW,IMO,is much better.
  #36
Old 04-23-2010, 03:27 PM
eds966tt's Avatar
Guys thanks for the help...Question should i replace the upper mounts mabe use tarett? or some other brand?
  #37
Old 04-23-2010, 04:50 PM
Depends on the condition of the OE mounts. A lot of our customers have re-used the stock ones since they were in good shape and have had no complaints. If your OE mounts are worn out, then you could got with an aftermarket set, but it's always hard to tell until you get in there and take a look.
  #38
Old 06-13-2010, 12:19 PM
silverlight's Avatar
silverlight is infamous around these parts
I'm late to this thread, but nvno1, what settings did you settle on with the KWv3's out of curiosity which has achieved the (relatively) smoother street ride? Getting a set this week and just curious to get feedback
  #39
Old 06-13-2010, 06:21 PM
eds966tt's Avatar
Silver light please post back your thoughts after the install. I have not decided yet for either pss10 or kwv3. thx
  #40
Old 06-13-2010, 09:15 PM
Will do. I'm putting on 19" rims and pilot sports at the same time, so going to have a couple variables going on, but will post back. Rgds
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
Nissan GTR
08-19-2015 02:11 PM
Quick Reply: stock ride quality versus PSS/KW kits
