stock ride quality versus PSS/KW kits
Been doing a lot of reading up about coilover kits. I am finding my stock 01 suspension feels floaty and harsh and needs to go. I was wondering if KW V3 kits and the like are harsher than stock. I will be only doing the odd track day and use on the street mostly and want more control at speed and less bouncy floaty road manners.
Cheers
Cheers
PSS 10's good for street, they handle better (less float) but are not any more harsh than stock. They are only so-so for the track. Be aware if you drop the car too much, you'll be looking at adjustable rear dog bones and toe steer links to get a decent street alignment.
I'm in the same boat. After only a month with this car, the suspension drives me nuts. Upon hard acceleration the rear just squats causing the front end to start getting light. Cornering does not have that taut feel that my Boxster with ROW M030 setup did. It is sloppy and rolly. It seems like the front and rear of the car do not work well together. A lot of this is just learning to drive the car and adjusting to its characteristics but there is much room for improvement. I will be torn between the coilovers and another M030 package. I'm biased to the M030 because it worked so well on the track and street in my other car. Hopefully, I will get to drive in a few other cars with various setups before making up my mind.
Personally I'm a huge fan of the KW kits over the PSS kits. The reason being is the additional adjustability. With the Bilsteins you have control over height and rebound adjustment on the shocks. With the KW's, you can control height, compression, and rebound on the shocks. That gives you the ability to fine tune the ride quality that much more.
Either one is a drastic improvement over the stock suspension. It's just a matter of how much adjustability you'd like over the shocks.
I would like to keep the stock ride height. Not sure if we have lower ride height RoW than the US but I can only just get into my driveway the way it is. The should not not present an issue should it? I mean if the kits are height adjustable I assume you can leave the height as stock and still have a measurable improvement.
I found my stock suspension to feel the way you described yours. I went with the kwv3 and got them from Tom at Rennsport who was awesome to deal with. I HATED the way the car looked/drove with the stock suspension. I couldn't be happier now with the kwv3s. I have the ride height set exactly where I want it which makes such a huge difference in the cars appearance. The ride is also far better. The ride is still stiff, but its not as harsh as stock. Stock it feels like you are hitting a curb when going over bumps. With the kws it feels like the curb is rounded off not square. The front end float is also gone which was my main issue. The front end float was making me insane! Overall it was money very well spent and I wouldn't change a thing.
LOOKS GREAT!! I'm glad you're happy with them!
As for adjustment, it's relatively easy on the KW's. The rebound adjustment is made at the top of the shocks, and the compression is made at the very bottom.
But, once you have them set up, you really wouldn't need to change them that often, unless you're attending a track event or something like that.
Ride height
Can any of the vendors on the board confirm that the USA ride height can be maintained on the 996 T with KW3 coil overs installed. This seems to be a question asked by a number of us, but I can't seem to find an answer to it. Don't want to spend $4k to find out that the car rides to low to clear driveways speed bumps and such.
[QUOTE=nvno1;2796319]I found my stock suspension to feel the way you described yours. I went with the kwv3 and got them from Tom at Rennsport who was awesome to deal with. I HATED the way the car looked/drove with the stock suspension. I couldn't be happier now with the kwv3s. I have the ride height set exactly where I want it which makes such a huge difference in the cars appearance. The ride is also far better. The ride is still stiff, but its not as harsh as stock. Stock it feels like you are hitting a curb when going over bumps. With the kws it feels like the curb is rounded off not square. The front end float is also gone which was my main issue. The front end float was making me insane! Overall it was money very well spent and I wouldn't change a thing.
Looks great! Did you install anything other than the coilovers and droplinks?
Is the car set to GT2 alignment and height specs?
I'll post them up first thing in the morning for ya.
P.S. How can you hang a Corvette poster so close to that beautiful Turbo? I love your wheels, by the way.
