Some disturbing news.
#31
Something tells me that maybe the rumors of flat 8 power are not far off, something to do with the large bore flat six not meeting future emissions standards. Because they did not build much headroom in these A91 engine it seems that maybe they are just a stop gap? If 4.0 is about the biggest the production engines can go than they don't have much more in them.
#35
Not based on any current Porsche engine design.
http://www.motortrend.com/auto_shows/geneva/2010/1003_ruf_rgt_8/index.html
I think I'll take this baby over any Porsche DFI engine...8,500RPM redline and a flat-plane crank. Can't wait to hear this thing.
- The crankshaft is a 180-degree flat-plane design for optimal flow characteristics and a "nervous" racing engine note.
- Connecting rods are titanium.
- The valvetrain is arranged spherically around the combustion chamber.
- Maximum speed is 8500 rpm.
- The block incorporates all coolant and lubrication passages.
- All ancillary accessories are driven directly by the crank or camshaft, so there are no belts, and most are mounted at the bottom of the engine to lower the center of gravity.
- Lubrication is dry-sump, with five suction pumps and one pressure pump driven off a common internal driveshaft. There are two windage trays in each gallery, and the oil tank is filled through an opening in the right rear fender as was the case on the 1972 dry-sump 911 RS.
- The V-8 package is the same height as the boxer, and just 0.8 inch longer. With a different transmission, it could be lowered 2.4 inches in the car.
- Total dressed engine weight is 88 pounds less than the 3.8L boxer six and is considerably more rigid than the boxer engine, which reduces friction.
- The engine meets current U.S. EPA and Euro V emissions standards.
- 542 SAE horsepower at 8500 rpm
- 369 lb-ft at 5400 rpm
#36
Corrected.
http://www.motortrend.com/auto_shows...t_8/index.html
yeah, I saw this video last night and could not believe it. I think Ruf has something with this, but the price of $300k+ puts it at a level well beyond what a 911 body should command IMO. I think if Ruf was going to go this way, they should have rehashed the late 90's street legal GT1 body panels and given the car a true exotic look. The engine seems like a piece of art. No accessory drive belts is a great idea.
#37
I didn't think it was Cayenne based, but that was the rumor that was out there. I wonder what the motor is based on, I find it hard to believe that they used a 100% bespoke block casting and built an engine not based on anyones dimensions or bore centers.
A flat 8 would seem like a logical next step to replace the boxer 6.
#38
BTW...when I said "corrected" I meant I corrected my post error...you were correct...I said flat 8 instead of V8 by mistake.
#39
I have a feeling Ruf knows that Porsche is leaving the GT1 engines behind and availability will be limited. Rather than use the Porsche's DFI engine, they've created their own monster.
Maybe they got the CGT V10 and cut two cylinders off it.
Maybe they based theirs off of this RSspyder V8 and did a bore stroke job to get to 4.5L .
#40
Even with Mclaren's bespoke 3.8 V8 they used the block and bore centers from an existing engine and engineered it for their purposes with Ricardo's help. Its just far too expensive to develop a completely bespoke block and casting for such a limited production car that is technically not a production car. So this engine has to be based off of something, I just wonder which engine it is based off.
