FINALLY!!!! K24 BILLET upgrade...
Old 04-19-2010 | 02:37 PM
ttboost's Avatar
Originally Posted by 80shilling
Yes, just with the 24's. With even bigger turbos, I assume you would need injectors AND a 5 Bar to get enough fuel to feed your beasts. From what I have been told, injectors and a 5 bar is way too much fuel for the K24 18G/20G and this new Billet.
Cheers..
Depends an what size injectors. I have been running 58lb injectors and a 5bar for a very long time now.
  #47
Old 04-19-2010 | 02:39 PM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
Yes.. That combo sounds good.. Because I am going 72 lb, I have been advised I don't need the 5 Bar as well..
  #48
Old 04-19-2010 | 11:01 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
I'm doing 72 lb Bosch injectors.. All the Tuners I have talked to recommend injectors vs. 5 Bar (they had a LOOOOOONG explanations for why, but in essence it's a fuel pump/pressure issue that doesn't happen with injectors, but is a problem with the 5 Bar.).
Originally Posted by 2muchtime
Is this just with the 24's? I'm running both inj/5 bar with larger turbo's though? would be interested in a short version of the looong explanations?
Cheers..
I believe a recent conversation I had with Tony had him telling me he is now doing/recommending both the 72#ers and the 5 bar together with alpha 28 turbos and similar.
  #49
Old 04-20-2010 | 01:36 AM
drjoe's Avatar
drjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the roughdrjoe is a jewel in the rough
570 pump 640 race
  #50
Old 04-20-2010 | 02:43 AM
flash68's Avatar
oh yeah forgot to guess #s...
578 @ 1.2 bar 91 octane
631 @ 1.4 bar 100 octane
  #51
Old 04-20-2010 | 11:11 AM
btapp's Avatar
btapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of light
How many people are actually running just a 5 BAR with their K24/18g setup and tracking the car regularly? Dave at EPL told me that they would max out around 500 whp which is probably fine, but is it safe?
  #52
Old 04-20-2010 | 11:15 AM
80shilling's Avatar
Originally Posted by drjoe
570 pump 640 race
Anywhere close to those figures would make me ecstatic....
  #53
Old 04-20-2010 | 11:27 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Technically... you need injectors with stock turbos if you push them hard enough.
Its just hard to sell a customer on something like that when others in the industry have been saying otherwise for a very long time...
  #54
Old 04-20-2010 | 11:28 AM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
I'll come in at $1!!! Oh wait I thought this was The Price is Right!
It should def. make some bad *** power that is for sure!
  #55
Old 04-20-2010 | 11:33 AM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
Is the design of these turbos going to be similar to the Billet 16's where they will only realy start to shine when running higher than what most would class as normal boost 1.3+ bar.
  #56
Old 04-20-2010 | 04:30 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
I think that bigger injectors just work better with the 5bar because it should help with good atomization and spray pattern due to the increased fuel pressure.
Maybe I'm wrong.
  #57
Old 04-20-2010 | 04:44 PM
Tony@epl's Avatar
Maybe I'm wrong.
Correct, but 3.8 bar is a fairly high start pressure.
We've used the 72lb injectors with both the 3.8 and 5 bars. In most cases the 3.8 is all you need.
  #58
Old 04-30-2010 | 10:48 AM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Any updates?
  #59
Old 04-30-2010 | 12:16 PM
80shilling's Avatar
Originally Posted by vr4henry
Any updates?
Nothing to report yet... About 2 weeks away from getting the Car into SCARGO to do the install...
  #60
Old 04-30-2010 | 12:31 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
curious, will you be staying with the 2.5 exhaust or upgrade to full 3"?
