What are your corner weights? Plus the truth about Turbo weight loss
What corner weight numbers are you seeing? (with and w/o driver)
Weightloss on my car:
- 2WD conversion (front diff, main shaft, half shafts)
- Rotec seats
- Afterhours exhaust w metal core racecats
- Rear seat delete
- Rear wiper delete
- Odyssey 925 battery
- GT2 decklid conversion
- Spare and tools
- CCW wheels 9x18 and 12x18
Weight added:
+ GMG Roll-cage (appr 40 lbs)
+ Racing harness (appr 10 lbs incl fastening points)
Total weight with 75% fuel level: 3349 lbs.
Total weight with 25% fuel level (= losing 32 liters) appr 3280 lbs.
Thanks for documenting all the weight loss/gain for the weight weenies!
I'm sure all those changes added up to one different driving experience for you, and hope that it's in a good way!
Unfortunately I did not weight it before, but doing a backwards calculation using numbers I weighed (wheels, battery, exhaust) and numbers from the weightloss thread, it shows how heavy these are. It has been weighed on a different set of scales about 2 months ago and those showed the same numbers.
It is indeed sooooo much more alive to drive.
Yeah totally...!! Yet they put in some impressive laptimes.
I'm baffled, as I have about the same weight loss mods as you and I seem to have started where you are now???!!! Maybe my car is not as light as I think it is?
It'd be cool to know some other true weights.
I weighed my car at the track on the track scale. (yeah, I know) I also weighed most everything that came out of my car. The only things I didn't weight were the exhaust (new) and the clutch. Found those on the weight thread. I seemed to have removed 250lbs or so and the track scale has me at 3150 (3340 with me), and the car weighs 3490 stock, so it seems correct?
I have a Tequipment roll bar (13lbs) and my sub is out too (12lbs). No Nav and changer for me.
RS GT3 RS
09-24-2015 09:27 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
