Engine On/Off Cycles before inspection?
Old 04-29-2010 | 06:26 PM
DRIVN Ind.'s Avatar
DRIVN Ind. is infamous around these parts
Does anyone know roughly how many on/off cycles a 996 turbo needs to go through after clearing a code (and it not coming back) before it is set to be inspected?
Old 04-30-2010 | 08:36 AM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
I think it's about engine run time/miles driven more than ignition cycles. I don't know the exact number, though.
Old 04-30-2010 | 08:38 AM
some cars its 50 miles some are a 100 miles for the readiness to set after the light is cleared. not sure what it is on the Porsche. i would do a 100 to be safe..
#TeamAIM
Old 04-30-2010 | 10:20 AM
desert996's Avatar
desert996 is infamous around these parts
Had to go through this last year. Its actually a complicated series of stop/start/idle/varying speeds that the car has to go through. I went to the DMV and they were able to give me a print out of the exact factory driving requirements to go through after clearing a code. If you go to your DMV I'm sure they can give you a print out as well.
Old 04-30-2010 | 10:48 AM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
It took my turbo about 100 miles...
Old 05-01-2010 | 08:41 AM
landjet's Avatar
I was told 50 miles by my tuner, and the last time I had to go for a smog check I reset my ECU to the stock program, drove 50 miles, then drove to the inspection station and passed the test.
Old 05-01-2010 | 11:01 AM
ard's Avatar
ard
The term I've seen is a "federal Drive Cycle" spec.
Although the prospect of the California DMV having a clue gave me a laugh!
A
Old 05-05-2010 | 11:32 AM
DRIVN Ind.'s Avatar
Man what the hell? I drove mine 100 miles with no code, and it still wasnt ready. Its up at porsche now getting the fuel metering code fixed then they are inspecting it. Im sick of dealing with it.
Old 05-05-2010 | 11:50 AM
ard's Avatar
ard
Different states have different requirements on how many "not ready" codes are permitted. Some of the readiness codes clear fast, others take longer.
drivn- are you just checking your readiness codes, or did a shop tell you 'not ready'?
Old 05-05-2010 | 02:05 PM
Put it up on a jack and put a cinder block on the accelerator. Just make sure Cameron doesn't get pissed at his dad and start kicking the grille.
04-28-2022 12:38 AM
nlakind
11-06-2015 10:15 AM
PelicanParts.com
BMW Vendor Classifieds
08-25-2015 03:55 PM
PelicanParts.com
08-25-2015 03:43 PM
Quick Reply: Engine On/Off Cycles before inspection?
