Check eng lite, ABS/PSM too, codes...
Old 05-05-2010 | 07:01 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
DME Codes ; P1601--660--CAN timeout instrument cluster
P1109--594--Input varibles charge
P0103--115-- Hot film MAF sensor
ABS/PSM codes 5525 -Incorrect data transfer w/ DME master control unit
Any ideas, suggestions?
Old 05-05-2010 | 07:40 PM
MBailey's Avatar
Boost leak?
MAF trouble?
Old 05-05-2010 | 07:43 PM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
I had some of those codes (no cel but 5525 PSM and ABS + P0103) when my alternator was on its way out.
What is volt meter reading?
When my alt was on its way out, I threw those codes - PSM/ABS lights on. Turned car off/on lights cleared. 2 days later - car would not start. Put in a new battary - car started - volts were low. Drove for a couple of days - volts went way high. Turned on high beams, heated seats, a/c - everything I could to get them normal and then drove it in to have alt replaced.
Old 05-06-2010 | 10:20 AM
drhenrock's Avatar
It seems to be holding and building boost just fine.
It did reset it self, can this be a passing thing? I guess I'll wait to see.
Old 09-26-2010 | 05:36 PM
andymac's Avatar
andymac is infamous around these parts
Was it the alternator ?
Old 09-26-2010 | 07:21 PM
drhenrock's Avatar
Alt fine, smoke test shows no leaks, replaced MAF, ...have AP IC's,hoses, TB/plenum Y-pipe, dual snorkle intake w/GT2 wing, and FVD flash/DV's, Car runs great still...knock on wood, getting ck eng and ABS/PSM every day...??
00aston
12-25-2015 12:11 PM
DB-Design-Group
Group Buys
46
11-03-2015 12:27 PM
jaehoppa
10-22-2015 10:17 PM
MJM911
New England
10-15-2015 08:39 PM
MrMiggy
09-14-2015 03:18 PM
