Clunking sound from rear suspension?
Within the last few weeks I have noticed a subtle clunking sound from the rear when travelling over bumps.
I have PSS9's set to GT2 ride height specs. Seth and I believe that it may be the plastic bushings in the factory strut mounts beginning to fail. We checked all the nuts for tightness and everything appreared to be okay yet the sound seems to be getting progressively more noticable.
I only have 6-7K miles on this suspension so it seems a bit soon for this to be happening but I was curious if any of you have noticed and what you have done to correct the situation?
i have the same clunking noise on my car too.. i think it's the swaybars too ill have tom at lucent check it out.. it happens usually in uneven places.. liek going up a drive way.. i think its the sway bars .. well i hope it is
Originally posted by greyghost
it just started a few weeks ago and I have had the PSS9s for over 6000 miles!
GT2 spec?? I thought using PSS-9's at GT2 spec meant you were riding on the bump stops? Any high speed stability issues that others have experienced with GT2 spec on PSS-9's?
Lou
04-28-2022 12:38 AM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
