FVD K24 Dyno 500+ rwhp :)
Went back to the dyno to get some pulls done. I went a couple weeks ago but my dyno runs did not get saved and we did not get torque. I wanted to have the run files so that i can use them as a baseline. Last time I made 516rwhp. This time I made 506rwhp STD corrected and 502 uncorrected. I dont have a stock dynograph on this dyno but my E55 made 500rwhp on the same dyno and went 11.4@123.5. My friends ESS supercharged E92 M3 made 499 on it the same day I made 516.
RWD
K24s
Cargraphic Exhaust
Bosch Motorsports 5bar fpr
FVD Tune
93 Octane
1.1bar peak, dropping down to 0.9bar
I wish it would hold boost better and make that power all the way to redline. Not sure why it drops off...
I will post some pics tommorrow.
RWD
K24s
Cargraphic Exhaust
FVD Tune
93 Octane
#TeamAIM
#TeamAIM
Are those stock k24's / stock wastegates. If so, you might want to consider upgrading the wastegates. I believe on the higher gears boost will peak and taper off after a certain RPM. Do you have a boost / AF graph.
these are the FVD Race K24 turbos. i do not know what "Race" means though. my wastegates are stock. i did log boost with my Duramtric cable on my friends laptop. i will get logs from him.
#TeamAIM
#TeamAIM
I have the same turbos- they are probably K24/26's - old school. Power comes up hard after 3500 rpm. Its interesting that theyre called 'race turbos' because they are hard to tame at the track. Great for highway pulls.
Do you have any 60-130 times?
They are not K24/26,FVD has K24/26 wich are laggy and has K24 race.
I have the same dyno on a 18g car with stock Wgs.... 1.1 bar as well...
I can pm it so you compare...
good job.. I had that FVD kit in 2002... ran well..
2001 996TT 3.6L and stock ECU
...either that or just ported a little. i do not think my wastegates are upgraded.
honestly the car runs good. i have made a lot of 1/4 mile passes on different cars. judging by feel and the dyno #s on that particular dyno (my friends and i have been using the same dyno for 6 yrs now) .....i would call it 11.3-11.5 if i can get it to hook OK at 125mph range.
i do have drag radials so i will take it to the track sometime soon.
#TeamAIM
#TeamAIM
Do you have any 60-130 times yourself ? I can get a pretty good deal on FVD24/26's with tune, so would be interested to have an idea of what they can do !
Last year on a stock clutch(that slipped like crazy) i rana few 1/4 miles at 12.5/122mph....keep in mind i'm also a novice driver. I now have a beefed up sachs clutch and plan to head back to the strip soon....stay tuned.
