Yearly/7k mi Plug Change With 1bar Flash?
My car had it's plugs change at 54k mi. At 60.3k mi it was flashed with a GIAC K-16 91 octane 1 bar flash with overboost to 1.1 bar in cool weather by a local sponsor. At 60.8k mi it developed a mis and flashing check engine light ~ 4k RPM. The sponsor determined it was the plugs, changed the plugs but not the coils since they inspected ok. The car was fine till now at 67k mi. It's doing the same thing. mis and flashing CEL at ~ 4k RPM.
Is this normal? Were maybe the wrong plugs intalled? Could a coil have gone bad?
I ordered a set a coils recently knowing I'd have to do them eventually, I just wasn't expecting to do them so soon. :lol: So what's the verdict on the best plug for flashed car?
Thanks in advance
Thanks in advance
I am going thru sort of the same thing right now. When the engine is under full load with full boost 1.1 to 1.2 bar, the car is misfiring really bad. This happens at the top of 3rd and 4th, 5th & 6th. My car has stock plugs installed currently. All of the research I have done points to the plugs being gapped too large. I've heard that the increased boost pressure actually blows out the spark causing a misfire. The stock plugs are gapped at 0.06"±0.008" from the factory. Under direction from friends and tuner, I am changing my plugs to a Denso 3245 (PK20PR-P8) Gapped at 0.028". I just picked up the plugs today. Everyone also advises me to change all the coil packs to 997's while i'm in there. I am going to try the plugs first just to see if this fixes the problem. If not, I'll be changing the coils. This gives me an excuse to hang out in the garage.
I am a noobie when it comes to p-cars. This is just my current situation. If any of this info is wrong, please correct me.
Well I did plugs today. I removed Bosch FR6's with stock 996 coils. The plugs didn't look too bad, some had carbon build-up while other still showed a little clean metal. But worst of all, all but one coil had small cracks.
So I installed NGK BKR6E plugs with new 997 coils from ebay. The car idles much smoother but I didn't get a chance to drive it. I'll report back once I have more miles on the car.
JH
I did mine at ~20k, getting occasional misfires. Noob at the time, so used stock plugs ... Coils were fine so I didn't replace.
Roll forward two years- Getting a misfire code at 5500rpm at WOT, so planning to change plugs. Will use bosch, FR6LDC. Also will replace coils with new 997 coils.
The nice thing about wrenching on a porsche?
Its a porsche.
A
Its a porsche.
A
Lots of competing opinions on plug heat range... seems 3/4 advocate stock, 1/4 advocate one step colder. Personally woudl only only go colder on a track car that sees a lot sustained of heat or maybe on a very extreme tune with huge turbos..
A
A
JH
Well after driving the car for a bit, the 4k rpm mis is gone!! Looks like the coils were the issue.
Like Ari said, lots of opinions on plugs. For one I don't mind a copper plug, second, I forgot to order the plugs and I wanted the car running this weekend so I needed a plug locally. And after reading this thread, post #3 and 9, I went with NGK
https://www.6speedonline.com/forums/996-turbo-gt2/99716-spark-plugs.html
Yes it is.
Yes it is.
Well I didn't like the NGKs after all. I don't know if the gap was too big but the car didn't feel smooth at 1.1 bar. It felt good at 1.0 but not 1.1. So the NGK plugs with a .028" gap are out and fresh stock FR6 plugs are in. Now the car runs like it should.
Also with the help of my assistant/tool girl, I did plugs in 2.5 hrs. :lol:
09-01-2015 03:16 PM
markski@markskituning
08-24-2015 10:07 AM
08-20-2015 12:17 PM
