Boost Hose Clamps
Old 06-01-2010 | 12:56 PM
btapp's Avatar
btapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of light
Boost Hose Clamps
I installed some new boost hoses with my K24/18 turbo setup and ran into the dreaded boost clamp issue. The hose connecting to the top of the intercooler on the left side of the engine bay is hitting the firewall due to the hose clamp being too large. Anyone know of any smaller clamps or any other solution that would work well? I searched and several people said to work with the clamp until it was seated on the far edge of the hose. This was not working either.. I would also hate for the hose clamp to be barely on the hose and blow off. Let me know if anyone has any suggestions.
Thanks,
Old 06-01-2010 | 12:59 PM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
t bolt clamps?
Old 06-01-2010 | 01:01 PM
btapp's Avatar
One other detail that I forgot to mention. If I seat the clamp as good as possible on the hose the intercooler frame sits off of the bolt slightly. I am sure if I locked it down I could align the frame. Question is that the air intake on the top side seems to be not sitting flush. I may attack this again tonight based on everyone's feedback. I would hate to go back to stockers due to just the hose clamp, everything else seems to fit perfectly.
Brian
Old 06-01-2010 | 01:03 PM
btapp's Avatar
Originally Posted by Blockhed
t bolt clamps?
Good thought but don't the T-Bolt clamps sit about as high as the screw in type? It is the height that is not allowing the hose to feed through the firewall far enough.
Thanks for the input.
Old 06-01-2010 | 02:02 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
i had the same issue with my k24's. i went back to the stock boost hoses.
Old 06-01-2010 | 02:11 PM
btapp's Avatar
That sucks! Did you use the lower ones at least and switch the top ones back to stock?
Old 06-02-2010 | 02:27 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Same thing has stopped me in my progress with this project. I think stainless steel cable tie type is the way to go. These require a special clamping tool and that you position the flanges prior to clamping.
Old 06-02-2010 | 04:12 AM
Porsche uses 3/8ths worm clamps on the inlet pipes to the turbos... they should fit vs the .5" that you often get... just a thought...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 06-02-2010 | 05:14 AM
robertp's Avatar
I kept the top ones and put the stockers back on the bottom. The silicone lower hoses popped off several times.
Old 06-02-2010 | 07:12 AM
btapp's Avatar
Thanks for the responses everyone. That sounds interesting about the clamp deal. Any pics or a link to that setup.
I wonder if I could just pick up a narrow clamp at a local auto parts store? Would that blow off immediately?
Old 06-02-2010 | 11:27 AM
btapp's Avatar
I just spoke with the Forge guys about the problem. They are going to check on machining a new piece that comes from the intercooler that is slightly longer than the existing part. In my opinion all of these companies need to make the machined portion longer going into the left intercooler hose to account for the clamp. I will let everyone know what I find out. I told them an additional 1" in length would do the trick.
Old 06-02-2010 | 01:29 PM
robertp's Avatar
pictures of the boost hoses. the lower hoses have been switched back to the stock black ones.
Old 06-02-2010 | 01:33 PM
btapp's Avatar
Thanks for the pictures. Interesting that the lower ones were causing problems. You said that they were coming loose correct?
Old 06-02-2010 | 03:59 PM
robertp's Avatar
They would pop off under boost.
Old 06-02-2010 | 04:02 PM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
I guess it all depends on what tuner you get your intercoolers from and how experienced they are with this problem, eh?
Quick Reply: Boost Hose Clamps
