k24 18g boost vs rpm
#61
Congrats, but something still must not be quite right, I have similar mods and my car can easily boost FAR higher then I want with pump gas.
When you get this sorted, you will REALLY feel it.
#64
cool... been thinking about doing external as well.
#66
think its X WG is worth it if i dont raise boost? really dont like the lag... suppose on an EBC, i can raise the gain.
#67
Dunno I will find out in a few hours.
It makes sense to me that having no actuator arm / flapper in the air path, along with venting the over boost directly to the atmosphere instead of thru the exhaust will increase flow, and reduce lag. The externals should be much quicker and precise since they are not "fighting" flow to open.
I have seen some trusted tuners here that do not like externals however, and do not feel that they help lag/hp at all.
Tom
Tom
#69
#70
I told you it was going to be a install problem... you should go over everything else...
something wasn't adding up especially when before the install it was ok...
mark
mark
2001 996TT 3.6L and stock ECU
#71
yea i was in denial. the indy's gonna get a lashing for this. wtf did i pay him for if i had to over n' do it myself. thanks for your help. funny thing is i went out bought all the parts to do the boost leak test at turbos, while waiting for epoxy to dry, took the airbox out, looked back there and saw the valve just chillin like a villian.
sdg1871
12-24-2015 12:22 PM
Fadi
10-05-2015 12:14 AM
