???X73 Carrera Race Suspension???
Old 06-08-2010 | 03:31 AM
Project911's Avatar
Project911 is infamous around these parts
Did anyone go with the X73 Carrera Race Suspension - Turbo/C4S instead of PSS9/PSS10/KWV3/etc.
Feedbacks please...
Old 06-08-2010 | 06:45 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
If this thread gets any traction, the first question is always, what are you looking for in a suspension upgrade?
I looked at both on the advice of my tuner (EPL) and decided on the PSS10s because they are adjustable while the X73s are not.
Around town I run on setting 5 front and 6 back. At track I run on 9 front and 10 back. Makes a big difference. Recently driving home from the track I had to pull over and dial them down because I forgot to at the track and they were vibrating my fillings over the joint expansions on the highway.
Also, set as above, so far at the track I haven't felt like I am outdriving the suspension by a lot, but if I continue, I may bite the bullet and get some real track shocks, though this will significantly hurt street drivability.
Flexibility is good for now.
Old 06-08-2010 | 06:51 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
Is the ride quality comparable to stock when your on the 5/6 setting?
Old 06-08-2010 | 07:19 PM
ard's Avatar
ard
Feedbacks please...
LVDell over on rennlist chose the X73 suspension... couple of posts on his rationale.
A
Old 06-08-2010 | 07:54 PM
joe731's Avatar
on 5/6, yes, ride quality is comparable. In fact, if I know I am going to be going fast, I often turn them up to 8/9 on street for better front end control. On stock front end felt "floaty" at speeds over 120 mph.
with PSS10's, especially on track where I often hit +140mph, car just sits there nicely
Old 06-09-2010 | 02:24 AM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I've had the X73 since 2006, I am very happy with it. Not too rough, not too soft. It lowers it a little over an inch but not too low. Thought I was going to need sways but surprisingly didn't.. they come with stiffer motor mounts but I swapped for the even stiffer RS ones after a couple years (there is a good market for used x73 motor mounts). While it's not adjustable like the PSS's, I also don't brainf*ck myself with seemingly endless adjustments.....and last but not least, the real beauty is the dealers have settings in their alignment machine for the x73 suspension option, which is pretty darn good :-)
Old 06-09-2010 | 04:13 AM
DS1's Avatar
DS1
DS1 is infamous around these parts
I have thought about going for X73, but went for a KW V3 (reworked from Manthey Motors).
Reason is that I drive a lot on the Nordschleife.
For street with occasional track... I would probably go for X73.
Old 06-09-2010 | 07:52 AM
landjet's Avatar
That depends on how stiff a spring set you go with. I went with Motons and they are way better at controlling the springs that I choose than the PSS9's I had previously. If you go to very stiff springs, then yes the street ride will be impacted. If you go to intermediate springs like I did and buy an upgraded shock, you will be surprised at how good the street ride can be and still give you superior track performance. The adjustability is what allows this. I think the secret is getting the right person{race shop} to help you pick and set up the combination.
My friend has a set of custom PSS9's that he tracks that were re-valved and re-sprung by Bilstein and they are completely different than the off the shelf variety PSS9's.
Old 06-09-2010 | 10:23 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Just about how much cost the X73 ?? anyone knows
Old 06-09-2010 | 10:30 AM
btapp's Avatar
btapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of lightbtapp is a glorious beacon of light
Go to Suncoast, they have the kit with the motor mounts. I think it is around $2500.
Old 06-09-2010 | 11:05 AM
rdss's Avatar
Thanks btapp
Old 06-09-2010 | 08:20 PM
SamboTT@ByDesign's Avatar
I have driven a car with that suspension. It feels like a factory well set up system. It even includes motor mounts if purchased complete. I agree with D33PBLU3 also that the more adjustments the more crazy you get.
I would say its like a PSS-9 (what I run now) on setting 5-6 also. Very nice. 1-2 wont work well on the road and anything above 6-7 floats anyway. 5-ish on a PSS-9 or X-73 feels right with the factory alignment on any surface. Pricey though. Try Suncoast.
Old 06-09-2010 | 11:23 PM
DEEPBLUE's Avatar
SamboTT is right on the money, it is one of the best factory option setups I have driven, Porsche definitely did their homework. FIW the GT2 setup is height adjustable, have absolutely no idea about cost, ride quality etc, but keep in mind it's for the GT2 which is a beast.
Sunset is good, I got mine through http://carnewal-europe.com, I am sure the exchange rate was a little better back then.
AJUSA.com
997 Vendor Classifieds
10-08-2015 06:50 PM
Sterlingc1975
08-22-2015 03:30 PM
PelicanParts.com
964
08-18-2015 04:57 PM
PelicanParts.com
964 Turbo
08-18-2015 04:56 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 04:42 PM
Quick Reply: ???X73 Carrera Race Suspension???
