Rear end noise - Kumho tires?
I have recently fitted 315/30/18 Kumho's (these replaced PS2's in the same size)on the rear and around the time of the fitment I started to notice a sound that could have been a wheel bearing. I constant whirring noise.I left the car with the local stealer, suggesting wheel bearing and they reported that it wasn't but it was due to the incorrect fitment of larger rear tires and the tires were touching the inner rear guard liner. The inner liners did show a slight contact mark so I bought tried 10mm rear spacers, however the noise is still there.
The sound is speed related, increasing with speed whether in gear or not. Is any body else having a lot of road noise with the Kumho's or does anybody else have any thoughts on what it might be? Now I'm not sure if I'm imaging it or if the car always had this amount of road noise...
TIA
Mark
TIA
Mark
TIA
Mark
TIA
Mark
Jon
Sorry to hear about that. I had some over sized Kumho's on my BMW and they SCREAMED. Didn't handle bad but the noise was impossible to live with. Got rid of those tires and the problem went away. Good luck.
Have had several sets of Kumhos....not noisy.
I still think its wheel bearings, they area known weakness....I have replaced mine.
The sound was an rpm related noise that would be drowned out by the exhaust as you went faster and the exhaust noise overtook it. Typical whining sound that changed pitch with rpm increase. It's located below and a little left of the power steering fluid reservoir. You have to take the airbox out of the way to pinpoint the noise source and to get at the tensioner.
04-28-2022 12:38 AM
COBB Tuning
11-09-2015 08:02 PM
Sterlingc1975
08-22-2015 02:30 PM
ModBargains
08-20-2015 12:28 PM
