Where can I find more info on durametric codes..
Old 06-18-2010 | 10:38 AM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
ABS/PSM light keeps coming on - code 5525 Incorrect data transfer w/ DME master control unit, as well as DME code, 115 Hot film MAF sensor, the car was just smoke tested after AP IC's, Y pipe, TB, Plenum were installed...? Thanks.
Old 06-18-2010 | 11:13 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
hot film: http://www.renntech.org/forums/index...ank-vent-leak/
PSM/ABS correlation with MAF post #6, OP also had same 5525 http://forums.rennlist.com/rennforum...f-new-dme.html
https://www.6speedonline.com/forums/...m-warning.html
post #5 here, same codes as you and same mods
https://www.6speedonline.com/forums/...installed.html
i have ap plenum and Y and AP IC and only ABS/PSM comes on sometimes at start. restart and it goes away. My indy traced it to a failed brake switch... car's 3rd brake light was stuck constantly half on so my issues may be different.
SI-CO 13
Cayenne Turbo
10-08-2017 02:37 PM
Vicelord
Ferrari
17
01-26-2017 12:50 AM
socialpro
Cayenne 958
09-16-2015 10:00 AM
EMC2
Cayenne 955/957
09-07-2015 05:20 PM
Quick Reply: Where can I find more info on durametric codes..
