Help My 2002 996 turbo doesnt want to start
I was driving my 2002 996 tt last week and the (FAILURE INDICATOR LIGHT) came on, which said that the temperature gauge was faulty. Then the car shut off and I couldn't get it to start. No fuel is going to the injectors. I checked the fuel pump its ok and the fuel pump relay was also ok. Do these cars have a fuel shut off switch? Please somebody help.
Often its not the pump but the fuel pick up lines...
2001 996TT 3.6L and stock ECU
Yes, that may be it
Should I fill it completely to the top? Earlier today I tested the fuel pump and it shot out gas when I added power to it with a jump box.
Chris Green
What code are you seeing?
I have no codes I disconnected the battery, when I was on the side of the road thinking that the computer would reset. I got this from the owners manual pg 86. (Failure indicator light for the coolant gauge not working). This sucks I just put a clutch in the car myself the other day because the dealer wanted to charge me $5,000.00, so I did it at my friends garage. Drove it home and the car was fine, next day going to work she died. sucks
It can be a broken fuel suction line (Markski) or fuel pump. Look at this link: https://www.6speedonline.com/forums/...ost-leaks.html especially "Porsche Tech" solution....
the older turbos (86) had a shut off mode on roll over this happened to me in carmel many years ago i was at the race track and a friend fix it for but it's been so many years ago i have forgotten what the fix was....good luck see if you have a shut off mode that may be the prob
