Engine coming out - what should I get done while it's out?
Old 06-22-2010, 12:05 PM
Hedonistic's Avatar
Hedonistic is infamous around these parts
Due to a reason I'll mention in another thread, my engine will need to come out. While it's out, what else should I get done on it while everything is easily accessible? It's a 2002 996TT with 58K miles
I'm thinking:
Water pump and thermostat
fuel filter
coolant tank
Clutch accumulator and slave
serpentine belt rollers and tensioner
alternator rebuild
any hoses? ALL hoses?
weld the glued-on coolant hoses
Anything else that is a "wear and tear" item on our cars that I should get done?
ps: I already did the plugs and coils, diverter valves and minor things such as the serpentine belt and oil and filter
Old 06-22-2010, 12:24 PM
raineycd's Avatar
How's your clutch looking? Great time for that!
Old 06-22-2010, 01:49 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
speaking of...good time for the GT2 conversion and get rid of some of that pentosin.
Old 06-22-2010, 02:44 PM
jpflip's Avatar
Old 06-22-2010, 02:58 PM
Hedonistic's Avatar
Do you mean a GT2 clutch conversion? Is that a heavier duty replacement? Mine's a daily driver and I don't track it. Should I just go for the OEM clutch?
Old 06-22-2010, 03:00 PM
ttboost's Avatar
Not sure how far you are willing to go, but rods and head studs will give you nearly a lifetime of reliability at most normal power levels, whatever those might be.
Old 06-22-2010, 03:01 PM
Hedonistic's Avatar
Yes great threads. I remember running across them now.
Old 06-22-2010, 03:50 PM
Dr_jitsu's Avatar
I would go with a GT3 cams and some headwork...you know, as long as you have her out
Old 06-22-2010, 05:07 PM
Hedonistic's Avatar
You rascals! Rods? Cams? Talk like that will start me down a slippery slope! :-)
I was more interested in preventative maintenance kind of stuff. The kind of stuff that will have me smacking my forehead if I find out later that it would have been dead easy if the engine was out.
Since I know I'm on an slippery slope: do engine mounts wear out? I've been reading with some interest about the Wevo mounts.
Also, there was a thread about transmission mounts needing doing. Is doing that more convenient if the engine is out?
Old 06-22-2010, 05:34 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I would do the 997 updated tranny mount and GT3RS motor mounts if you dont mind a little extra vibration and you do any sort of track events.
Old 06-22-2010, 05:55 PM
jpflip's Avatar
Very good suggestion for the tranny mount and more info here: http://www.renntrack.com/forums/show...mount-upgrades
Old 06-22-2010, 05:58 PM
AlanS's Avatar
AlanS is infamous around these parts
Thumbs up I would consider the IMS Bearing Upgrade
Check out http://www.lnengineering.com/ims.html I think the current month's Excellence has an article by Tony Callas describing the procedure. I had Tony upgrade the bearing when I had my clutch replaced.
Old 06-22-2010, 06:10 PM
jpflip's Avatar
I think that doesn't applied to the 996 turbo being a completely different construction. See pics.... TT on the left and 996 on the right...
Old 06-22-2010, 06:23 PM
AlanS's Avatar
It can still happen
Check out this link http://www.youtube.com/watch?v=qQ8mNVI9_G8 996 Turbo engine with x50 package. Agreed the IMS failure is less frequent in turbo cars, but cheap insurance if the engine is out.
Old 06-22-2010, 06:33 PM
jpflip's Avatar
This is something completely different and it is a major failure and this require engine opening. It is not a preventive maintenance action... Sometimes due to bushings #15 or 16 and sometimes due to a slack chain, worn chain guide, damaged chain tensioner....
Quick Reply: Engine coming out - what should I get done while it's out?
