Car stall @ low speed (MAF changed)
car only dies and low rev ie: @start up when the AC are turned on..sometimes even stall when turning into a slow corner (2-3KM/h)
I've changed a new MAF recently. ABS/PSM are keep coming on and off!
its driving me nuts!!
plz help!
thx
plz help!
thx
I'm the same boat .. but I was getting MAF errors (PSM + ABS) rarely though ... would go away after I restarted that car ...
I did the CEC Electronics cleaner from Ace Hardware thang ... it went away ...
Its just starting to come back again ... I'm curious what it is as well.
Anybody?
Anybody?
Anybody?
Anybody?
do you have a upgraded clutch....
2001 996TT 3.6L and stock ECU
I had this problem, and it turned out to be a split hose on the fuel pump. Showed up sort of randomly at idel, or turning a corner. No lights though.
Easy enough to remove the cover and sending unit to take a look for the split hose.
Jon
Jon
this could be anything from a vaccuum leak, to a bad replacement maf, to o2 sensors, to brake sensors, to plugs, to fuel line crack, to new fuel pump, to throttle body, dv leak, boost hose leak, to...
I think the best place to start if you are DIY is checking all the boost hoses. Mine was doing the same thing and I replaced my upper hoses with Agency power y-pipe, replaced the dv's with a 50/50 bov, replaced the exhaust with speedtech, replaced the lower boost hoses, and had EPL tune it. One of those fixed it!
Nola, you did use it as an excuse to mod.
Yes! All I needed to buy was a set of regular old boost hoses. hahah
My logic to my wife was "while I fix that, I may as well......."
