Transmission Help - first gear
So, it looks like I have more of a problem with my transmission then just a failed slave.
Last week I had the GT2 conversion done, and it is great. However it has not solved my problem with engaging first gear and sometimes second gear. Every other time I try to get into first, I feel a "rubbery" resistance and I cannot get into gear unless I do a few rapid clutch engage / release cycles. Gears 3-6 are fine. Nothing feels grind-y, or makes any noise. I have about 4k miles on a "stage 4" clutch.
Looking in the archives this sounds like a failed throw-out bearing perhaps.
I don't want to throw any money at this till I find out what 6speed thinks!
Tom
Tom
Transmission was replaced for 2nd gear pop out about 20k miles ago.
The PO put a OEM 996 SSK in, and I have no idea if it was adjusted properly.
I put a 997 shifter in about 1,000 miles ago, using the included tool, and marking the length of the rod to the threads.
I would LOVE it if this was a cable issue, as that I can fix.
Actually, how do you align the cables if you have no idea where to locate the throw?
Tom
Tom
Tom
Tom
This sounds like something in the gearbox itself. Maybe bad synchronizers, or operating sleeve. Certainly check the little things first, but I think that you are going to find out that the gearbox needs some more help.
Let me know if I can be of any help to you.
Erik Johnson
GBox Performance Transaxle
(303) 440-8899 work
(303) 895-4828 cell
www.gboxweb.com
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
www.gboxweb.com
if the transmission was replaced within 2 year, you are probably still covered under the warranty.
1 and 2 are on the same axis/fork. It sounds to me like a linkage issue. I think you need to fiddle with the adjustment, especially since there was a change to that 1000 miles ago and I am guessing the problem didn't exist beofre that?
Tom
This car had the transmission "replaced" for 2nd gear pop out at the dealer several years ago. My shop believes this was a factory defect, that was made worse by the power levels this car is at. The good news is that the transmission was in excellent shape and due to the angle of other gearing no extra damage was sustained. Car has essentially a new transmission in it now!
jaehoppa
10-22-2015 09:17 PM
