BMW forum trash talking and Drag race vids...
Old 07-02-2010, 11:02 AM
Dr_jitsu's Avatar
Like I said....and remember I am an owner and big fan of the E46, it is not the right platform for a very high hp turbo set up.
I have a built motor and couldeasily handle a HPF 2.5 turbo set up but the car is much more enjoyable w/ a SC.
I am planning on getting the new T trim which will up my power, but it will come on steadily, unlike a turbo.
  #257
Old 07-02-2010, 11:03 AM
Divexxtreme's Avatar
Originally Posted by SCM3
Hey man, i agree lol. Thank God i have a manual boost controller or i would throw this car away already...
I will do my best! Im hooking 2nd gear damn well in about 800whp mode and they tires are inflated to full 36psi at the moment! So i can see it holding 1000whp if i lower the tires. Nevertheless i will do my best, i will try to go 60-130 and a 100-150 various boost levels.
FYI; I run my DRs at around 22 psi on the street.
  #258
Old 07-02-2010, 11:05 AM
SCM3's Avatar
SCM3 has a spectacular aura aboutSCM3 has a spectacular aura aboutSCM3 has a spectacular aura about
I will try that for sure!
  #259
Old 07-02-2010, 11:06 AM
CURI0's Avatar
CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !CURI0 Is a GOD !
With over 43,000 E46 M3's being sold in NA compared to only 10,000 996TTs, I'm pretty sure there are far more modded E46 M3's than modded 996TTs.
With turbos?
Also, the modding for both cars started about the same time (back in 2002-2003), but the Porsche is just much easier to modify and started out with turbos from the factory.
Exactly the Porsche is much easier to modify and has a larger base of guys who are willing to take it to the higher power levels. The Porsche turbo crowd has had a reputation for doing this for a long time.
I think it has to do with platform limited traction. And in my opinion, if you can't hook, there's no point in even producing the power.
That is definitely part of the problem.
  #260
ttboost's Avatar
That was my point in yesterdays "other" thread. Why build a fast car from a platform with so many shortcomings? Making power is easy, you need SO much more to use it...
  #261
Old 07-02-2010, 11:07 AM
CURI0's Avatar
This is just a matter of perspective. The SC will never make the power of the turbo. I would go turbo if I could as the linear powerband is not my goal.
The SC also does not have the response of the motor in NA form although the powerband is similar.
It is a fantastic platform for a high HP turbo setup. The S54 is just an incredible motor.
  #262
Old 07-02-2010, 11:11 AM
exactly ...
#TeamAIM
  #263
Old 07-02-2010, 11:14 AM
I came to this same conclusion back in 2005 which is why I left the M3 scene and moved to Porsche. For my specific purposes, it was obvious to me that the Porsche Turbo was a much better overall platform. I believe that's still true today, just as it was back then.
Only my opinion of course.
  #264
Old 07-02-2010, 11:17 AM
ttboost's Avatar
I would tend to agree, but I need an LSD, axles and a Tilton to agree 100%.
  #265
Old 07-02-2010, 11:20 AM
Dr_jitsu's Avatar
Its not perspective, its physics.
Front engine w/ no room to run anything larger than 275s vs rear engine and 315s plus.
Also the S54 has to be built to handle big power. The Metzger handles 800 rwhp all day.
Seriously, your ignorant statements are just embarrasing yourself.
  #266
Old 07-02-2010, 11:25 AM
CURI0's Avatar
Of course the S54 has to be built, it is 11.5:1 stock compression since it is NA. However, once built, it is an animal and can take almost anything you throw at it since it has that beefy iron block and incredible heads/valvetrain.
Even on the stock motor it can hit well over 600 whp, impressive. The 996tt rods are only good for around ~600 whp so how is that any different? It needs to be built as well.
You can run wider than 275 but to really be able to put huge hp down you definitely have to address the rear tire width in a similar manner that SCM3 or Taza here has done. That, or go with a widebody. Yes, traction becomes an issue. Happens on many platforms.
I'm sorry, but I'm embarassed an E46 M3 owner does not know more about his own platform. An HPF turbo will just flat out destroy the SC S54 M3's, period. Taza has traction issues because he is making more power than... everyone. So yes, he has problems with his 1000 whp setup but for the most part M3's are low torque and high HP so traction is not as big of a deal as most of these guys are making it out to be. Read up, please, and yes, SC vs. Turbo is a matter of PERSEPCTIVE not PHYSICS.
  #267
Old 07-02-2010, 11:26 AM
Dr_jitsu's Avatar
Here is one thing I will say.....which car is more FUN to drive on a road course?
IMO, it is the SMG E46, an absolute blast.
The Porsch (of course I would go w/ a smaller turbo for a road course) will have a faster lap time, but is not as enjoyable.
  #268
Old 07-02-2010, 11:28 AM
Dr_jitsu's Avatar
Where did you ever get the idea that the 996 rods will only handle 600 max?
I have been running mid 700's, and Powell dynoed 868 on a stock block.
  #269
Old 07-02-2010, 11:31 AM
made it up along with several other things
#TeamAIM
  #270
Old 07-02-2010, 11:32 AM
CURI0's Avatar
From this forum? Are you really advocating the stock rods are good for 868 whp and the motor is going to last for something more than peak dyno pulls?
I mean, Protomotive seems to believe that once you start getting out of that 6xx whp range you are pushing it on the stock rods. Maybe they don't know what they are talking about?
You have to build either motor if you want to get in the upper ranges so it is a moot point.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
Quick Reply: BMW forum trash talking and Drag race vids...
