Another USP E85 ethanol conversion on the dyno!!
Old 08-19-2010, 09:44 AM
Chris Green@USP's Avatar
Chris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond reputeChris Green@USP has a reputation beyond repute
Originally Posted by Sunnyside
Can the system be run with just water and no meth... ie tuned on the rollers to do so. Would it still give good results.
I'm running k16's with standard I/C's but a revo stage 2 tune and 100 cell Miltek exhaust.
Frank
This is a fuel system not an add on meth system. its doesnt run pump gas. Its runs strait E85.
  #32
Old 08-19-2010, 09:49 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
Sorry
Frank
  #33
Old 08-29-2011, 03:48 PM
roseylv's Avatar
roseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to all
Chris,
I just sent you an email in regards to an E85 systems.
  #34
Old 08-29-2011, 04:39 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
chris pmed you i forgot i also am running evo how much thanks steve ics
  #35
Old 08-29-2011, 04:49 PM
so i go down to my local station and fill up with E85 amd thats the deal no water injection... just googled e85 sez it,s 85 cents a gal. can this be true
  #36
Old 08-30-2011, 12:39 PM
johnspeed's Avatar
Does are fuel system components handle the E85 fuel mix,as far they will not deteriorate??
  #37
Old 08-30-2011, 06:22 PM
can i stiil use 100 oct fuel if E85 is not to be found ???
  #38
Old 09-01-2011, 09:06 AM
No way... gas and e85 are not even close when it comes to AIR/FUEL ratios.
  #39
Old 09-01-2011, 05:05 PM
mistersamu's Avatar
mistersamu is infamous around these parts
Great jojojojojo
  #40
Old 09-01-2011, 09:25 PM
vr4henry's Avatar
vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !vr4henry Is a GOD !
Chris,
Fantastic numbers. Quick question -- how close are we to having a usable 'flexfuel' style setup (if at all?). I'd love to have the ability to run e85, I have a pump a mile away... but that's the only station for like 100 miles in any direction. I'd probably run out of gas before I could get to another, and it certainly wouldn't be easy to take a trip anywhere.
Even if the answer were to reflash via a cable that would probably work well enough... thoughts?
  #41
Old 09-01-2011, 09:36 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by vr4henry
Chris,
It's already being done with several 997tt cars from Protomotive. I believe KPG's (Evoms) car can switch back and forth. Skeeter is currently building a completely flex fuel 997tt with Switzer.
  #42
Old 09-01-2011, 09:42 PM
vr4henry's Avatar
Thanks for the tip -- I'll try to dig up what I can on those cars. At least KPGs is a 996, but it's heavily modded so who knows what EVOMS has in there for a tune
  #43
Old 09-01-2011, 09:49 PM
TTdude's Avatar
Check out Venkatreddy and twturbo. The injector size will determine if you can run both gas and E85.
  #44
Old 09-01-2011, 10:07 PM
Turbo Fanatic's Avatar
Chris, I know you and EPL make great products and I am not doubting or in any way question your ability and or that your cars are FAST as hell.
I am seeing though that dynojets typically have this "flat" HP curve. Doesn't look very realistic.
Here is my personal car with the BPU upgrades on K24s dynoed years ago. Dynoed by a third party. Same flat(ish) HP curve... seems to be a hallmark of dynojets. Is this the result of the dynoject not being a load dyno? This could also be the result of tuners not really tuning out but welcoming the torque spike which may result in this flat HP curve.
What are your thoughts on this?
  #45
Old 09-02-2011, 06:08 AM
vrybad's Avatar
vrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant future
My thoughts on this and the original chart posted here.
I don't think there is any issue with the dyno on either setup, just that it appears your setup has been pushed a bit harder (more aggressive boost/timing) nearer to redline, or your turbos are simply more efficient (they are K24's).
Just a guess, though, since I don't know your tune particulars, but your chart looks more typical, with hp kind of climbing as rpms increase.
When I look at the original chart, I see torque peak at about 4600rpm, and peak hp occurring at about 5000rpm, when in a fully tuned setup, peak hp typically occurs nearer to redline.
This leads me to believe there is a bit more left in this setup at the big end, unless the turbos are running out of breath.
Torque spike has nothing to do with a flat HP curve.
That spike can be tuned in or out.
Personally, I always tune to increase torque as redline approaches, but that may not have been possible in this setup (or he is keeping the good stuff for later!)
I'm also guessing he tuned the car to limit torque around 4600 and keep that engine together.
If torque drops hard as rpm's increase, then the hp curve will tend to "flatten" out.
The car goes from 630 torque at 4600 to about 450 torque at 6500rpm, losing nearly 200 lbs in a 2000rpm span.
In a dyno run, the most "force" is being applied at the torque peak.
As rpms increase, "force" drops (not "speed" or "rpm") and the resultant hp curve drops as well.
That's why, if a car can be tuned to increase torque (force) as rpm increases, the result will be a climbing hp curve.
The car should still be a performer, but has a lot left on the table with a better turbocharger.
Quick Reply: Another USP E85 ethanol conversion on the dyno!!
