E85 q
Old 07-04-2010, 08:47 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Question E85 q
What modifications running E85 requires, except bigger injectors and ECU tuning?
Could it still be run with ordinary gasoline, and if yes, will there be automatic program switch ( some Fords can do this ) or is manual switching necessary?
Who provides the required soft- & hardware?
As usual, using "search" was not much of a help...
Old 07-27-2010, 02:13 PM
pete95zhn's Avatar
And as usual, no answer for a specific technical question. Not even that std "Ask your tuner" quote...
BUT, I got information from a local Bosch representative about turbo's OEM injectors. According to Bosch datasheet they're rated 443 cc @ 3bar. Thats 500 cc @ 3.8 bar or 575cc @ 5bar.
BTW, here's a link to Bosch Motorsport datasheet about EV-14 injectors: http://www.bosch-motorsport.com/cont.../html/2659.htm
And a link to Bosch Motorsport datasheet about 5 bar fprs: http://www.bosch-motorsport.de/conte.../html/2829.htm
Old 07-27-2010, 02:40 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
The question is how much HP are you looking to run.. I have done E85 conversion in cars and changed nothing at all.. Normal parts to be changed are Injectors, Pump & Tune.. Give us some more info to better help you.. Thanks!!
Mike
Old 07-27-2010, 02:43 PM
Mr swed's Avatar
Mr swed is infamous around these parts
Hi pete95zhn
I think that the cars that run E85 an gasoline has a alcohole meter in the gas tank or fuel line that messures the fuel/E85 mixture and adjusts the ecu there after (Saab 93,95 biopower) but I'm not sure. If you’re switching between fuels you should switch prog manually. Then there’s the Q that always arise when you convert to E85 and that is if the material in seals/tank/hoses and the fuel pump can withstand the E85.
This is just my thoughts
Old 07-27-2010, 02:46 PM
Originally Posted by Mr swed
Hi pete95zhn
Correct the flex fuel cars have a sensor that measure the Ethanol content so you can switch between fuels and ECu adjust mapping accordingly.. If you do it on a car that is not flex fuel standard you need to swap maps when you swap fuels yourself.. There are ways to add that sensor into a standalone type setup but its far too risky IMO relying on it to change mapping..
Mike
Old 07-27-2010, 09:56 PM
pete95zhn's Avatar
OK, thanks for the thoughts about map switching and sensors. To get most out of manual map changes ( and also out of E85 ) you'd need always fill in a full tank of fuel. Then there's the question about correct map with correct fuel in manual change and remembering to change.
Still -IMO- two maps is a necessity unless E85 is available in every pump in areas you're going to use that car.
I'm going to be at 500-550 crank hp area, but is there a rule of thumb -so to speak- how much larger injectors one should use with E85, compared to gasoline?
BTW, in that link above about FPR's the one suitable for 996 turbos is E85 compatible. I happened to buy one of the last old ones...
"For your future information, this pressure regulator is being upgraded to be compatable with E85 fuel. The new part number is 0 280 B02 722-02 and is more expensive. When our stock of the 113 fpr is depleted we will stock the new upgrade."
metzkaro
09-30-2015 12:48 PM
Bobbyfali
09-27-2015 01:55 PM
Quick Reply: E85 q
