stock sway bar settings 2001 turbo
has anyone went through the setting options front / rear . my car is basicly stock with a tune. settings are on mid front and rear. is stiffest on both front and rear just stiffer for roll than mid with same ballance.
I have my sway bars set at second hole from soft front and second hole from soft rear, and have found the car to be very neutral at those settings and I track my car. I have a completely upgraded suspension so maybe that's what the difference is. Some guys like full soft front and full stiff at the rear. Of course, driver preference also comes into play. Experiment and see what you like best.
I guess your swaybars are not stock. 01TT has no adjustable one. So your might got change from previous owner. May be time to check what brand you have.
ok. i will check if i can see a part number. this only 996 i have so i dont have any referance. the sway bar is white and has 3 holes for adjustment. ( info from memory ) i will look tonight when i get home. had to bring another car so i could pick up another set of rear tires getting mounted. i will have to check the rear camber. i am only getting about 1500 mi on used sets that have 60 to 70 % tread on them when i buy them. ... very worn on the insides. cords showing on last set.
2lflat4
11-18-2019 05:05 PM
r_matt_6
10-08-2015 06:07 PM
