GT2 Clutch mod without replacing clutch
#31
anyone have the part numbers needed for the conversion?
#TeamAIM
#TeamAIM
#32
Slave Cylinder 99611623790
Master Cyl 99642317106
clutch assist spring 99642308113
hydraulic line 99642337790
plus the plug and hex cap, and 4 bolts to attach. I would just buy a vendors kit and get support. The $150 you save is not worth the trouble of putting this together, but hey each to their own
Tom
Tom
#33
From dgreen78
The OEM Porsche parts you will need you can get them cheap at Pelican Parts online (total $368.00). You will need the following:
You will also need some DOT4 fluid. Optional is the DOT4 cap so down the road a tech doesnt put it Pentosin. I dont have the part # but it is the same part as your brake fluid cap.
Instructions can be found in this post:https://www.6speedonline.com/forums/...ns-help-2.html
#35
Tom
Tom
#TeamAIM
#TeamAIM
#36
#37
Post # 22
I just looked into one as well, John from Speedtech just sent me a bunch of info that seems straight forward, check him out. There was nothing about removing the tranny? EVO kit seemed straight forward, good diagram instructions.
#38
You just need tiny hands...
#39
This kit has been done in a garage on jack stands with the tranny in, but is much easier and safer on a lift. The tranny does not have to come out. IMHO, you are beter off buying the complete kit and having support as tvurt mentioned.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
#40
So what makes the 1000$ kits different from buying the parts yourself from a dealer for 360$ ?
#TeamAIM
#TeamAIM
#41
1) the bracket
2) the bolt set, and plugs
3) support
worth it imo. The parts are $389, and say 200 for a bracket, then you have to source the bolts and plugs. Huge pain in the butt.
3) support
#42
The total is actually a bit more than $360. $360 gets you the master cyl, slave cyl, clutch assist spring, and hydraulic line. You need another $200 for the bracket that attaches the cylinder to the transmission. The kits also come with a DOT4 fluid cap to make sure no one puts pentosin in the reservoir. They also come with a pair of brass hose plugs and a hose clamp. I think they also throw in some DOT4 brake fluid. My guess is that to put the parts list together yourself comes out to less than $600.
The extra $400 gets you someone to call if it all goes wrong
#43
thx for the info. when you say 200$ for the bracket - is that to have it fabricated?
#TeamAIM
#TeamAIM
