What drill best for Stock Exhaust Mod?
I'm thinking of giving the STock Exhaust Modification a try while still pondering what performance exhaust to purchase.
Is the hole saw shown the best bet? Should I go with the full 2" or maybe a bit smaller since the pipe is curved. Trying to figure how the heck to get it started on a rounded pipe? Seems like it would be darn near impossible to get it started. Any suggestions for making this go smoothly.
ALso it seems like someone said to drill towards the outside/inside to get more room and not drill through the back wall, but can't recall.
Thanks.
Thanks.
Thanks.
Thanks.
If I find it I will post the link.
It was good reading !!
Frank
I wouldn't use that bit. I bought one and returned it. Used a die grinder with 2 long carbide bits to make my ~2" holes. When you do get a aftermarket exhuast I'd purchase SpeedTech cross-flow (76mm) or Markski's system.
I ended up using an Irwin Unibit which I got at Lowes. I put it on an extender to get it into proper position--it did a really nice job
If you want to go bigger than the bit, start a second hole near the first and just join the two.
![Cool](https://www.6speedonline.com/forums/images/smilies/cool.gif)
I used 2 13bucks bits from Lowes and a good wired drill. It took me 20 minutes to get it done.
Had to fish out one of the cutouts that fell inside the muffler tho...
Air. started a pilot hole with one of the bits. There were "oval" bits. 1 more aggesssive than other.
Look, even I could do it. Read it, god it even tells you the size of Bur to use...............
Frank
Thanks.
Thanks.
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
