Torn dust boots--how big of a deal?
Old 07-07-2010, 11:19 AM
ttboost's Avatar
Originally Posted by DERBOOST
you need to add a posi in the rear if you r gunna do it, and be sure thats what you want as you have to cut up your front axles to get the sensor gear for the abs ect. So ur hacking up a 1500.00 pair of axles, also you really should do the gt2 uprights as well.And a larger rear swaybar, not to mention a gt2 ecm or try to get the tt ecm to not have the psm come in so soon. All told to do it right its a considerable expence. Yeah you can hack the axles and not do anything else, now you have a car that does not handle as well as what you had, yeah it seems faster because its scarry to drive at the limit,and may in fact be better for drag racing stuff. but IMHO a well sorted 4wd tt is a better car than a non posi no front axle deal. But If you do all the mods correctly (like a gt2) it works really well.
And yes ive driven all 3 types on a track, gt2,996tt4wd, no posi 996tt 2wd
I don't disagree, but actually you do NOT have to hack up the front axles. They come apart at the clip. If you ever go back to AWD, just clip em back in and grease...
Old 07-07-2010, 11:38 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Interesting, i've done 3 conversions on early 996tts and had to cut the cv apart to get the stub shaft, I wonder if there was a change in later cars? that would also let you rebuild the cv instead of buying a new axle ?
Old 07-07-2010, 11:44 AM
ttboost's Avatar
Maybe that's why my first time doing the conversion took 2-1/2 hours Once you pull the axles, remove the grease and all the ball bearings (6 or 8 *****?) and the "cage", you will see a small clip on the spline way inside. Just reach in with small needle nose or circlip pliers and I believe you sqeeze the clip and the stub axles just slide off like butter.
Old 07-07-2010, 12:00 PM
g8rdmd's Avatar
g8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to behold
Originally Posted by 2muchtime
Nice, thanks for the pics, doesn't seem as dark as mine? maybe because of the black exterior?
Yeah, the black may throw it off a bit--I think it has faded a little, too--the car spent much of its life in the Florida sun without being tinted before I got to it
Old 07-07-2010, 12:03 PM
DERBOOST's Avatar
cool, i'll look at some of my old axles and see if its there, thanks..
Old 07-07-2010, 12:28 PM
ttboost's Avatar
No Problem
Old 07-10-2010, 12:11 AM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Does car need to get alignment after this? Thanks.
Originally Posted by atr911
and the joint gets damaged. The grease will be very messy aswell.
The price quoted sounds very reasonable to remove and reinstall the pair of boots as they are pressed on and not fun to remove.
Old 07-10-2010, 05:07 AM
ttboost's Avatar
I re-aligned mine as I went to RWD, but I would imagine NO, if just doing the boot repair.
Old 07-20-2010, 03:56 AM
aroonkl's Avatar
Anyonelse knows if alignment is needed after boot repair? Thanks.
Old 02-01-2011, 06:28 PM
xeattle's Avatar
xeattle is infamous around these parts
It is required to re-align as you have to remove the steering knuckle which has you popping off the the ball joints and the mount to the strut so you can pull the axle shaft out to fix the boots...or even when you're doing a 2WD conversion it's the same process.
Here is a shot from Pelican showing everything that is removed...I wouldn't believe the alignment would be exactly the same after hooking all this back up...
http://www.pelicanparts.com/techarti...l_Bearings.htm
Old 02-02-2011, 09:07 PM
MrWhite's Avatar
MrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond reputeMrWhite has a reputation beyond repute
Aren't NEW front axles on Pelican or Suncoast like $300 each? Sounds like a ripoff to fix the boots at that price.
It's an easy diy to swap axles btw.
Old 02-02-2011, 10:39 PM
xeattle's Avatar
Question
http://www.porscheoemparts.com
Part # 99634903810 @ $427
Has anyone seen this for less?
Old 02-02-2011, 11:25 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Originally Posted by IAPorscheDoc
Get it done asap. If you get crap in the joints, it will ruin them, and then you are looking at buying new axles
+1 get it taken care off asap
takenotes996tt
01-20-2016 06:34 AM
LuvPorsche
11-11-2015 10:37 AM
Quick Reply: Torn dust boots--how big of a deal?
