Custom ECU Flash Erase???
It sounds like I have problems that I didn't know about. The car is running well overall. Are there any symptoms associated with too much boost and improper AF mixture that I could look for?
I have only seen the 1.3 bar once and it was for a very short period. Typical driving yields up to about 1.0.
Jon
The car might feel like its running well but you dont know the harm you might be doing.
Avoid anymore WOT until you know what the full extent of your modifications are and have a Durametric read out.
Just my personal opinion.
Keep telling us whats going on,
Cheers
Frank
I have a solid 1bar tune from UMW. I sometimes see a spike to 1.1 but it doesn't hold. 1.3 is pretty high. You might want to do some more research from the previous owner as to what you have.
I'm out in the Frederick area. I don't drive my car much on the street. Come over to Summit Point July 17 & 18 and we can meet up. FAST FWD will be there too.
The concern is that if your car is running lean, you can cause serious damage to your motor. Detonation and preignition cause major problems. And at those boost levels, that is a serious concern. Most pump gas tunes are at the .9-1.0 range for safety. Just my 2 cents.
K16s run out of steam at 1 bar, you're just overworking your turbos without any additional gain.. You're not getting an ounce of more power above 1 bar with K16s. Are those the turbos on your car?
I believe that the turbos are stock k16s. I had the car at a local tuning shop yesterday for unrelated maintenance and they felt that the 1.3 was not an issue. They have seen the 996tt with even higher boost with no problems.
How can I tell if I am running lean and what kind of damage does that cause? I don't mind buying a durametric but I wouldn't know what to do with the data that I collect. I really don't have the funding just now for a custom tune, especially given that the car is already tuned. I'm avoiding full throttle as a precaution until I have some time to work things out.
If I were you IMO, I would find a good well known Tuning shop near you or in your local area (6 speed members might help there) with a Rolling Road and have a full check.
They will tell you whats going on with your car. I'm not saying buy another flash, just get a full power check.
No guess work, you will know how much your car has been tuned and you will know if it is safe.
"You Must Do This For Peace Of Mind". It will be well worth the cost in the end.
(Standard k16 should not be putting out 1.3 bar especially at the red line.)
Sorry for all the Neg Vibes, but I do truly hope you post back with good news.
Frank
I'm kind of in your position with a new to me car and overboost issues. I took mine to a dyno to check and that I was running lean. I was so lean that the ecu was pulling timing to try to protect the motor. Lean leads to detonation or preignition in the cylinder. Higher octane fuels resist preignition and improve your air fuel ratios which is why others have recommended race fuel till you get it sorted.
What can go wrong happened to me with an old 944 turbo race car of mine. Overboosted inadvertently, detonated, collapsed a piston which grabbed the piston rings and scored the block so badly I lost all compression in that cylinder. Then metal all thru the oiling system and blah blah blah. Think expensive.
The durametric is an easy to use program that can tell you what is happening. Search the board and it'll tell you how to use the thing if you're interested. It'll record a lamda value that can be translated to a/f ratios.
I'm not trying to be doom and gloom here, but you do need to sort this out. As others have said, 1.3 bar is beyond what is needed or wanted for stock turbos and is potentially very bad for your motor. You could be ok, but you don't have all the info yet to be able to be sure. If your local tuner was a Porsche guy that's one thing. If he's not, the TT is a different animal from what he may be used to.
Others smarter than I will probably do a better job describing the situation, but that's how I see it.
Good luck sorting. Just think how much you'll learn about your car!
Dude, trust me, ask anyone on this forum. K16s are not made to boost to 1.3 bar. You are overspinning the turbine. After 1 bar you are just working your turbo for no reason. It does not produce any more power. 1 bar is the limit for a K16, the local tuning shop is misinformed.
I wasnt sure how much a RR tune would be over there, it would be about £100 just for a check here I suppose.
A Durametric is a great tool and I would suggest you get one . I bought the pro which was £750 about $1100 over there. BUT on this occasion you dont want to be Pi$$ing about with a Durametric if you dont know how it works. Time for that is when the car is ok and you do some learning runs with it and learn how it all works. For now you must find somebody who will do a RR run and tell you the full story.
Do get a Durametric but do get a pro to Run your Car. The sooner the better.
Frank
If this "tuner" is just doing oil changes for you, that's fine. If he is in any way involved with your engine tuning, you need to find somebody else. This guy doesn't know 996 turbos. That's not to say he isn't good on other cars, but I wouldn't trust him with an engine that costs more than some BMWs (as in an entire car off of the showroom floor) to replace.
04-28-2022 12:38 AM
nlakind
11-06-2015 10:15 AM
09-01-2015 03:16 PM
08-20-2015 12:17 PM
