HELP - Need PPI with Warranty?
Guys - I need your advice. I have a 2002 911 TT that I am looking at and it has a full bumper to bumper warranty for another year that is transferable. I have read through it and need to read one more time, but it seems very inclusive.
Do you think I still need to get a PPI? I am leaning toward no, since everything would be covered (there are NO mods on the car at all) and I would prefer to put the additional money towards extending the warranty.
Thoughts? I need to make a decision quick, due to some other options, so I thought I would come to where my friends are and ask for the advice.
Feel free to give thoughts...car as 39k miles and doesn't appear to have anything wrong with it. No 2nd gear pop-up, clean car fax, etc. So give me your thoughts...
A PPI should be non-negotiable, even if the car has a warranty. Do you really want to deal with issues, minor or major, even if they do end up covered by the warranty? You could get a total POS and the warranty isn't going ot make you feel any better.
I didn't get one before I bought my CPO 03 Turbo with 9500 miles on it last year. But I gave the car several good goings over and a longish test drive.
In your car's case with just one year's warranty remaining I'd have a PPI done. My car had a 2 year, 100K CPO warranty.
Dry bearing noise appeared last May and I found a radiator fan not working. Took car to dealer for this and tech found in addition to a bad roller bearing, a busted radiator fan hub/blade assembly (which took out a radiator -- no leaks but dented the back side all to heck) a selector shaft seal leaking on the transmission.
To fix this required the transmission be replaced. Under warranty.
Since you have a year left on the warranty the earlier you can spot something needing attention the better. A PPI can do that for you.
Oh, and radiator cap found to be leaking and replaced too. My advice based on my expeirence is the radiator cap does not end in 03 or 04 just buy a new one and replace the old cap. The old cap if not leaking will leak eventually.
Sincerely,
Macster.
Sincerely,
Macster.
Just because the car has a warranty, does not mean it does not have problems mechanically or prior accident history.
Have it checked out- a good indy mechanic can be a lot more thorough and less expensive. Have a Durametric scan of the car, including over revs.
l1. You have no idea what might have been on the car previously. "told", yes- "know", not hardly
2. Any evidence of 'abuse' or 'mods' that might be present can invalidate the warranty when you go to use it. Indeed, the warranty may be out of business or may not transfer (although I assume you have the POLICY and know what needs to be done)
3. Prior repairs- mechanical or body- will not be covered by the warranty.
4. Deferred maintenance is not covered.
There was a recent story here (thread is hibernating) of a person relying on a cpo...turns out the car had major mods that were stripped out, the dealer slapped a cpo on the car and it still had modified software- so if he ever tries to use the CPO and PCNA finds out it will be denied.
PPI is a must
A
All good advice. I have all the service records and have confirmed via an independent printout from Porsche. I have a copy of the warranty in hand and everything is solid. Looks like the PPI is coming though...thanks guys.
Also there is no 'standard porsche PPI'...every dealer does it differently- or should I say you never know what they'll be doing.
I recommend doing the "CPO Checklist" so that you know what is inspected and what criteria is being used, and ADD to that a dump of the DME for any errors, codes or overrun data. Surprisingly the latter is not part of a porsche CPO.... they clearly don't want to find bad news they cannot do anything about during a cpo, but are more than happy to use that data later to deny claims... (Who, me cynical? )
A
A
A
A
Get the PPI. I have a aftermarket warranty that was transferred and is "comprehensive, highest level package, guy paid $4k for 3 years." I'll tell you from experience that they are scum bags and will say everything is maintenance. My ignitiion switch failure (porsche wanted $525) they said maintenance, my tensioner/pulley/belt for $2.1k they are saying maintenance; weather proofing strip on driver's window = maintenance.
Get a PPI with compression and leakdown test. If they find anything, use that to negotiate price and dont' get stuck with 4 figures of "maintenance" expenses right off the bat.
Pain in the butt = YES. PPI = YES. Worth the warranty = YES!!!!
