Taller drivers?
Taller drivers?
Ok, I' going to be in the market for a 996tt here in about a month or so (also considering the C6Z). I was just wondering how the interior fit is for taller drivers. I'm 6'4 and 225, athletic build, I didnt have too much issue with my 04 Cobra I had before and the times I've driven a C6 those didnt feel bad either.
So taller guys chime in!
Same here. But I did put in a smaller stearingwheel and longer hub.
Depends on whether you are legs or torso. Back in 2001 I ordered a 996TT (one of the first to hit the streets) and had to order the sunroof delete option to fit in the car. I have no problem with my 997 with the sunroof. I am 6'2" but 32" inseem. Sit very high in a car.
I'm 6'6'', 220lbs, athletic build and have a 02 996tt. I have plenty of head room, but leg room is a little bit of an issue since the steering wheel does not tilt up (its fixed). It does periscope a little, which helps. I'm fine with the tiptronic, but no way I'd be able to comfortably work a clutch unless the wheel tilted up (like the 997 does, but not 996).
