Differences between brands of billet DVs?
Hey guys, I was thinking about buying a set of billett diverter valves since they are so inexpensive and an obvious must have for any plans to run higher boost down the road. I was wondering if there are any kinds that are better than others.
Also is this a DIY job? It seems like it should be. Looks like there are only a couple of hoses to move out of the way. If there is a DIY guide on this out there somewhere, I'd love to have it. Thanks
Eric
Eric
The OEM style DVs are maintenance free. I had set of evo billet DVs, but by the recommendation of UMW, i got a set of bosch DVs. The non oem style billets supposedly build up oil and you will need to clean the oil for optimal performance.
I also attempted to install them, however it was too difficult and the local shop did for a good price.
Great thread, thanks OP. I'm also wondering what most guys say on here. I'm considering changing my 50/50 BOV for a set of billet DVs. I keep hearing about the Forge Motorsport ones but from the looks of it they are all relatively the same. I don't mind the maintenance of the billets since they are more precise than OEM at doing their job. I'm looking to do the EPL flash soon and everyone has said I should switch over to billet DVs.
I've had a set of Agency Power billets for about 6 months now without a problem--so nice not to have honking geese in my ears
I did it myself--easy job but tight spaces. REALLY helps if you can lower the engine.
I see you have a silicon F-hose. Did you do that upgrade at the same time? Worthwhile to do that as well while I'm in there?
UMW sells a set of Bosch ones that hold more than 1 bar. UMW stated that there will be oil build up from other aftermarket type DVs.
you cant use a TRUE BOV unless you convert to a blow through system, without it ,its metered air you would be disposing of and will throw your tune off and you may get a cel.
