Wheel upgrade question (fender rolling)
Got a line on some beautiful 19" hre's. need to run a 10 mm spacer in the rear. I have stock euro ride height suspension. Do you think there will be any rubbing? Will I need to roll the fenders?? pics are with a 5mm spacer. Did not have all the wheels,or long enough lugs to do a test drive, but as of now there is about an inch of clearance.
More help needed before pulling the trigger..
Tire sizes on the rims are 235/35 and 295/30 19.
will these work or will, or will damage be done. tried to search but could not find the old thread I was looking for on tire sizes. TIA.
What are the offset and width?
I'm running 19x11.5 in the rear with a +33 offset and 315/25/19 tires. I'm also on PSS9's. I think I heard the tires rub the fenders once on a hard mid turn bump.
I'm probably going to get the fender lips rolled a little.
Not sure of the offsets right now. More concerned with the tire size and if they will cause damage to my differential.
thanks, that's the info I was looking for.
