Ok, how long will a drum of race gas last if you use some here and there?
Old 07-19-2010 | 11:24 AM
unvmy996's Avatar
as the title sates gentlemen, i have a 55 gal drum of race gas,since december. i have used some here and some there, but sealed it tight as i can , and stored at pretty much room temp ,and its sitting on a concrete floor.
can it go bad ?anyway to test it?
Old 07-19-2010 | 11:48 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
Email the vendor . .. I was going to get a 55 gallon, but I read that you lose 1 point per month! I would love to hear what someone like VPRacing has to say about this.
Tom
Old 07-19-2010 | 11:50 AM
MBailey's Avatar
Not claiming to be an expert, but stored race gas does loose octane over time even properly stored. Air leaks and heat simply accelerate the process. Properly stored it looses octane points slowly like one each month. If you dont use a drum in two or three months I would buy smaller quantities.
Old 07-19-2010 | 11:51 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
Drum shouldn't last that long if you race the car. You should fill it up on weekends and go hunting. I have a drum of VP ms109 coming I'll use it up by mid fall.
Old 07-19-2010 | 11:59 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
I buy the sealed 5 gal containers to avoid unsealing more than needed.
Old 07-19-2010 | 12:08 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
You have no worries if it is stored tightly (no air leaks) and at room temp. There is nothing in there that will decompose over the time frame that you need to worry about. To get it analyzed is not simple. To do it right, you need to use gas chromatography and would have to compare it with a "fresh" sample and have standards of each component in the fuel. Even different batches of "fresh" samples would like show some variability based on the source of crude oil. You're fine. Just use the tank within a year, mainly so you can enjoy it!
Old 07-19-2010 | 12:09 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
I used my drum up already and thats from me being stupid and driving the car every day as a daily driver with 109 in it. But i want the 100% protection that its there when i hit it and dont want to say well there is more in it i just cant show you till i fuel up.
If you have had it since December i would say you may have lost a bit of the rating once it cracked open, You did store it in a Cool dark dry place thought right?
Old 07-19-2010 | 12:14 PM
TTdude's Avatar
Yeah, I'm thinking about doing the same thing since it's not my DD.
Old 07-19-2010 | 12:16 PM
It should not stand on cement either....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 07-19-2010 | 12:18 PM
Also to get the maximum acceleration performance from your car is to lessen the rotating mass weight. To achieve this all you have to do is release all the air in your tires & replace it with Helium,this will not only relieve some of the rotating mass but also lighten the cars overall weight.
Old 07-19-2010 | 12:21 PM
bbywu's Avatar
Mark brings up a good point. I've been told that race fuel should not be stored on concrete or in plastic containers because nitromethane can leech out. Not sure if this is truth or myth.
- bob
Old 07-19-2010 | 12:22 PM
unvmy996's Avatar
That's what i ussualy do but beeing that we got raped this winter and cinders salt stuck around for a long time I didn't have all that time to drive her.
Drum was in my garage at room temp I sucked 10 halons out of it and then sealed it tight as I could.but did store it on a concrete floor.
Old 07-19-2010 | 12:56 PM
ttboost's Avatar
Hmmm...yeah, it's no good now...I'll be down this weekend to pick it up and dispose of it properly for you...
Old 07-19-2010 | 01:02 PM
And if you need a hand i can help!
Old 07-19-2010 | 01:04 PM
DJM's Avatar
DJM
DJM is just really niceDJM is just really niceDJM is just really niceDJM is just really nice
I have heard the same about concrete and plastic containers
Quick Reply: Ok, how long will a drum of race gas last if you use some here and there?
