1st (Ethanol) E85 Porsche 911 Turbo by Prototech & Protomotive
In south Florida, E85 is available all year round.
If there are slight variances in fuel quality, the factory 997tt ECU has the ability to make up to 25% positive and negative compensation across Long Term & Short Term Fuel Trims.
Keith
Keith
Right, it's called 'E85' year round here also. But sometimes it's e65 or e90. This plays havic on fuel and timing maps. It's the biggest reason I've not switched one of my cars to it. Of course, the ECU I'm using is also not as adaptive as the Porsche unit; so this point is likely moot for you. Happy to hear your experience has been better than mine.
Yes, the O2s function perfectly with E85.
After 1.5 bar of boost the 997 MAFs are maxed out and the O2's are then what keep the AFRs in check. Kind of scary to rely on the O2's under high loads when they periodically go bad from time to time.
We are working on an inducer to help keep AFRs in range over 1.5 bar. Once we are done, under extreme loads, short terms will be kept in check.
Much safer setup.
Keith
Much safer setup.
Keith
Been testing E85 for 4 months now nearly every time I have filled up. The quality is always atleast 85% ethanol many times it looks to be around 90%+.
So far I havent run into a bad batch. Not saying it wouldnt happen but so far we have had lots of luck around here. I know Mike at AWD Motorsports has run his EVOs straight into the 8s in the quarter mile using the same E85 pump I go to myself.
Keith
Keith
Quick question Keithta
Hi There. I live in Pompano Beach and I'm pretty sure I saw your car on the lift the other day when I stopped by to check in on my Protomotive 996 TT that blew cylinder #3 (50 miles after purchase...not cool). Anyways, wanted to ask you about your experience with Prototech. I've heard mostly good things, but I've heard a few mixed things recently, and my car has been sitting there for a month pretty much collecting dust. I'm trying to decide whether I should just bite the bullet and ship it up to Todd Knighton in AK. I'm also thinking about re-sale...that Protomotive is much more well-known. Any thoughts??? Don't get me wrong, I'd rather have it done 10 minutes down the street, but I'm getting mixed signals.
Also curious to hear about your experience with E85. I figure if I've got to blow a load of money and they're in there mucking around already, why not spend a little more
Thanks,
Jason
Thanks,
Jason
Jason,
I had protomotive do my full build with e85, it was Todd's first in house e85 build and he was amazed at the performance. First the e85 is amazing and its about $1/gal cheaper than pump for race gas returns, its a no brainer as long as you have it readily available. The conversion is pricey if done right, all fittings and seals will have to be replaced as e85 will eat them over time.
As for taking the car to Protomotive, I made the mistake of convenience when having other setups installed, I literally took years trying to right the problems. I dont know Prototech, but I do know Todd, Cyn and company - I give my highest recommendations without any reservations.
Thanks,
Jason
Thanks,
Jason
the reason why your car is probably still sitting there is , they probably have a lot of cars to do before yours.
did you ask them when they will start your car ?
Jason,
Im thinking seriously about talking to Protomotive about converting to E85. I have only run a couple tanks of race gas and def dont plan on running it full time due to the fact that I rarely have a need to go into boost over 1.1bar and at $11.50 a gal its just not cost effective. Could you tell me.what you know about the swap to E85? I already feel like I have a good.base for which to make good use of E85 with a set of GT3076's, intercoolers and whatnot. I am.assuming ill need fuel pump upgrades as.well as lines and injectors. What else is involved other than those items mentioned and of course tuning? Thanks for the input.
Jason,
Who said that e85 will eat threw lines and fittings? I call bs. Only cars that this is a problem for is is pre early 90's cars. Our government made automotive companies use ethanol safe lines ect way back then. The evo's, rsx type s,s2000's, that are year 2000till now. Have run on stock fuel lines for years now on e85 without issue. Sounds like a p-car tax scheme to me.
