1st (Ethanol) E85 Porsche 911 Turbo by Prototech & Protomotive
Finally converted my turbo over to an E85 Ethanol fuel system by Prototech & Protomotive.
I understand Dave & Todd can apply same packages to the 996 TT as well.
Check out my full write up here:
https://www.6speedonline.com/forums/...otomotive.html
ha! ill run into you at one of those pompano gas stations! how many fuel pumps you runnning..you should have had USP hook that up for you, they have done a bunch of those conversions at good value
Good job.... I wondered where you were.. lol
2001 996TT 3.6L and stock ECU
I know 60-130 times will suffer, but if I can pull off a solid time in the heat, that should give us a good idea of what the car will be capable of when the temperature drops 50 degrees this winter!
Thanks. Should have some more info soon.
Originally Posted by Divexxtreme
This is one of the most informative posts I've read in a long time. Great stuff, Keith! Rep for you!
Nice job!!! ...and more importantly, what's that Panamera run 60-130?
First? We did this with Chris @ USP back in Feb of '09...
https://www.6speedonline.com/forums/...orn-horse.html
1st High-Powered (Ethanol) E85 Porsche 997 Turbo by Prototech & Protomotive
its on a 997 though and not a 996 .
Now I say this in disrespect and I could be wrong myself. The 996 and 997 fuel system internally and externally, minus the bigger fuel injectors from the factory. Now I know Keith did not want to lose trunk space, which is completely understandable. But we used a surge tank setup on mine because the lack of a CLEAN install of a triple intank pump setup that would work correctly with everything (This was preparing for the built motor, no need for 3 pumps at my current power level).
Regardless it is good to see more e85 cars running around. I wish we had it more in my area. I know of like 3 stations and 2 of them are the closest at about 10-15 miles from the house.
