Roll Call - 996 Tiptronic Owners
#196
31. lawrencew83 - EPL alpha 28 kit /w injectors, 74mm IPD plenum /w upgraded TB, 3" speedtech cat-less xflow exhaust, EVOMS intake, 911tuning intercooler, KW variant 3 coilover, techart swaybars
#197
Might as well check in officially...
2001 Seal Gray:
- UMW flash
- 911Tuning custom exhaust (coming soon)
32. Tiptronicus - '01 Seal Gray coupe: UMW flash, 911Tuning custom exhaust (coming soon)
2001 Seal Gray:
- UMW flash
#198
I have mine for almost 4 years but I do not do the quick double pump. I usually just leave it on D, press the rocker once (or twice) to downshift and step on the gas at the same time. I found this way is the quickest for me.
I don't usually use the M mode exept driving on winding roads, where I don't want the car changes gears on me.
#199
#200
I hear ya. To me, the shifting speed for using the rocker and double-pump is the same; but the human time is much quicker using my thumb.
#201
Maybe I am wrong, but I found shift down and floor it is not boosting as fast as the way I mention, although I didnt make it successfully everytime, but if I could do it in the right way, it boosts up like a rocket. And thats why I want to have a more clear procedure....
#202
I believe you're all stock, right? With the right tune, the boost should come almost every time. Once out of blue-moon, if I feel the boost is not there, I would downshift one more gear... and the boost is there for sure.
I somewhat remember someone mentioned the double-pump would shift faster, I don't like it has anything to do with the boost.
#203
And so it may the difference that yours has been flashed, another story. Mine has boost everywhere too, but not having the max at once if just floor it.
#204
Let me know if anyone is interested in the latest version TCU 99661818004. I bought two (long story) so have an extra...
It made my D mode so much better...it has a ton more driving programs. Supposedly it has 250 programs versus the 2001 tiptronic tcu (part number ending in .02) that has 5 programs and it also shifts quicker.
Furthermore, I believe the earlier version TCUs are not "tunable" by evolution motorsports as I they tried to tune my early version TCU, but it never worked.
The 2001 and 2002 turbos have older version TCUs. I think if you have a 2004 and most 2003s have this version (latest gen).
I just posted it in the classifieds (will sell cheaper to tiptronics that have checked in! )
#205
#206
I have a 2004... that's why I don't have the same Tip problems/issues other people complained.
My guess is... your next step will be a TCU program upgrade; you'll enjoy the 7k shifting!
#208
its under the passenger seat...if you have a rollcage its difficult to get to. you can just check the part #
You might be able to tell with a obg2 scanner or computer, but not sure.
