ECU mod or flash download??
#46
Ponzz, thanks for putting this "entry level" question out there. I am a new 996TT owner as well and I have the same questions as you do. UMW and EPL are both at the same price point and I am still not sure which one to go with. Even after doing my research at RL and 6speed, there's still no real clear cut winner...which still keeps me on the fence.
Decisions, decisions...
#47
I think that you will get alot of EPL fanfare here, but also other car makes and forums. I do not have EPL, but I would in a second based on prior purchases from them and their service. I have spoken to Kevin at UMW and he is very helpful and knowledgable as well. I am not sure about UMW, but EPL writes their own software there and they have great on-site support and code knowledge. Other Audi friends have had custom code changes in a day without issues or downtime. Try to get that from an off the shelf GIAC tune? No way. Personally I would never buy a tune from somebody that cannot get changes as needed.
Another thing to consider is that some "tuners" don't actually write code. They pay somebody else in Europe or even the states to do it for them and they tag their name on it. I would run away from those guys as fast as you can. You want to be communicating with the people that are at least in the same state as the tuner This will get a timely response to tuning changes and issues.
#48
UMW is the same. I have a stock program, valet, 91 octane and 100 octane files
#49
I believe tho for UMW, you need to buy the hand held flash device in order to reprogram as needed...which almost doubles the price. The basic $1K special only includes the rental of the device for 2 weeks. I see EPL touting that the $1K special includes a cable...but what else can we do with that cable?
#50
To me price wasn't a major criteria, it it was I'd buy an Upsolute.
To be honest, I rarely swap files-
#51
I am somewhat biased towards EPL because Tony has been a friend of mine for over 2 years and even before I had an EPL tune he was there to answer all of my questions. He has tuned both of my setups including the current one when it made 843rwhp on a stock DME. He knows the ME7.8 so well it still boggles my mind! If you knew how he learned and his background in programming you would understand that everything is done in house including his own flashing tool. Let's just say I've been using it for a long while. With the addition of Robin and guys at the shop like Dave you cannot go wrong. The Powell family will have another EPL tuned vehicle maybe as early as next week! We will be taking a 997TT and give it some loving really soon. My brother will not be going as crazy as me though, because he hates changin fuels, etc...
#52
Does going with EPL cause any problems with emissions in California? I think EPL allows the post cat o2 sensors to be disabled as well if you get exhaust Cel's but does that cause problems with Ca smog?
#54
As I understand it, turning off the O2s will give on one 'readiness not set' code... so if there other issues with the car, or you've recently done a reset, it COULD take some time to set all the other readiness codes.
#55
Technically it is not "CA legal" but will "pass" if you don't tell them.
#56
Most flashes will pass california smog. Being AWD, the turbos don't even get on the rollers. Your biggest issue will be passing the "visual" test if you have an exhaust. If the smog guy is a d*ck, then he'll fail you after doing the whole test pass or fail for having aftermarket cats. That happened to me a few years ago.
Make sure the smog place is cool before takling your car there.
Feelgood MD
03-24-2016 09:35 AM
gadgetman
09-10-2015 03:29 PM
arhim22
09-07-2015 08:49 PM
