Misfire Question
Misfire Question
Gents,
Looking for some help. I have the mods in my signature. I recently had 72 lb. injectors installed and left the 5 BAR FPR (for now) due to availability. Car drove fine on Friday on the way home from the shop but I did notice some hesitation a few times in between gears at WOT. Had a track event planned and made it 1/2 way through one session and the CEL came on with a few misfire codes. Found a place across from the track and swapped the plugs, I think they were NGK or something since that was all that was available at the time. Same problem again. I limped home and the car was running poorly.. Sputtering and missing pretty bad. I can reset the ECU and the car seems to run o.k. for a moment then the CEL comes on again. Changed the coil packs, same issue. Cleaned the MAF thinking that may be causing the issue.. No dice. Any feedback would be appreciated.
Car was perfect before the injector install on Friday.. They had the quick connects so I doubt that any of them are loose..
Maybe it was trying to adapt for a day and failed?
Don't forget you can use the drive links on Durametric to shut down each individual cylinder to determine which one has the misfire.
Frank
Frank
Thanks. Any chance that the tune may have not loaded properly? I thought about asking if I could reload just to eliminate that as a cause. I cleaned the MAF sensor with electronic cleaner so that isn't the problem.
Sure... Ill set you up to reload if you would like. Lets get the proper fuel pressure regulator in the car before we do anything else!
Thanks Tony..
Exact same problem I'm having.
see post: https://www.6speedonline.com/forums/...96tt-here.html
My shop is still puzzled...
I'm interested to find out what your problem is, and I'll let you know when I find mine.
btapp,
See my earlier post, my problem was finally fixed with replacing the MAF (not cleaning it). The codes kept saying misfires though. I would try replacing the MAF. My shop switched one off another 996tt to see if that was the issue before ordering a new one.
Good information, thank you. I just passed this along as well. I may have to do the ole try and buy!
One thought.. I also disconnected the MAF and the car still ran like crap, I assume that may rule that out as a problem. Not sure but just wanted to pass this along.
HotRod
09-10-2015 07:17 PM
