I bearly beat a EVO 6
#32
Rolando...
you need some ICs, injectors, plenum from airbox to turbo, and a EBC.. put some better gas and then go back to race that Evo...
2001 996TT 3.6L and stock ECU
#33
I know Mark,i am saving for the ICs,WGs and boost controler...i let you know when ready.....i hope it doesn't keep taking so long as so far.Then i am going to race back that Evo and beating good.
#34
if you are investing so much money into your car at least race for some money people of El Salvador must pay to stay next to the most powerful Porsche of the country!
#35
I agree Alex but i am scare to get borrough the car without knowing and never see it again.........so i am happy to just race for them to have fun
#36
aha...so it must be a lot lighter than the newer models. you have to realize that the new Sti with 310 bhp traps low 13's at 102 ish. So there is no way your 340 bhp will get you 11.7 unless you have about 1100 lbs less in weight.
#37
so the new one is what about 3400lbs? That is 800 lbs difference and 30-40 bhp more. interesting stuff. any other mods that helped you gain time? The numbers just don't add up. I can see low to mid 12's. it is a full 1320 ft 1/4 mile right?
#39
5 Speed box on non STi Models. Had an uprated gearset fitted as the torque ripped 2nd gear apart on the standard set. TMIC, so minimal lag. The setup just worked.
Yes, full 1/4mile, ran 11s at both the permanent official drag strips, with runs all backed up.
It certainly isn't the norm, most Imprezas of the same weight require 450+bhp.
exactly. very impressive numbers.
#40
Other than tune do you have DV's and good german cats? Stock K16 cars are running mid 11's here.
#41
the best 60ft time I have cut in mine is 1.9, my average 60ft time is 2-2.2
10-02-2015 02:23 PM
