Can't control the boost on my GT28 hybrids, what should I replace them with?
Colby
All of your problems are symptoms of a bad tune. Keep what you have, load the EPL tune and datalog for Tony. You will be stunned at the results. My car has stock boost control...never overboosts and has all the protection of the ECU. You would be doing yourself a disservice not loading the EPL tune, you already have it. Oh and fix your boost leaks first!!!
with GT28's and a Giac tune and the car ran flawless.
This is the first thing i would look at......Mark is right ......get the car to someone that knows these cars and have everything checked.The last thing i would do is change the tune.The tune may very well be the problem but i would leave that as my last resort.FYI i had a similar setup
04-28-2022 12:38 AM
BlackMarketRacing
12-08-2015 01:49 PM
