BBS LM's OR BBS CH-R's
You can't go wrong with either, I'd personally go with LMs. The nice thing about the CH-R is you can get the black versions with pinstripe or just silver, both are nice. What color is your Turbo?
LM-Rs are nice but the 19x11s are narrow body offsets so they would need big spacers to work. CH-Rs are 19x12 which on a 996 with 315/25/19 = slightly stretched tires. They work better on 997s IMO. LMs come in 19x11 with 50mm offset which is the best fit for 996 Turbo. Could still use some spacers though
I have CH-R now in black.
They are a nice wheel, but with 315/25 the tire really is a bit stretched on the 12" rim.
I think I will go with the LM:s for next summer and the 11x19 rears.
How much of a spacer should I use with the rears ? 15mm ?
Ellll Emmmz for the win.
Here is what I would do...
1. Put 15-18mm spacers on the rear wheels and that will make them sit nice.
2. Get different lips for them to make them 11 or 12" wide. Bigger lips will give them a nice deep look and they will also not cost you more then 800-1000 for the pair.
Good luck
Good luck
#TeamAIM
#TeamAIM
I'm putting LM's on my GT Silver Turbo S next week and can't wait!! I was thinking of going with LM-R's but just couldn't get past the timeless and clean look of the LM's..this will be my second set of LM's (first was on my E39 M5) and my brother has them on his E46 M3!
SM_ATL
18
07-05-2016 08:41 AM
away
04-27-2016 03:53 AM
johnnyg996
09-30-2015 11:19 PM
