Fuel system matter
Fuel system matter
Hi guy's
As I'd explain on another topic, I 'd some noise's became from the fuel tank and /or carbon canister purge system
The fuel pump noise I heard was hight on volume similar than a buzzer, what is strange is that I heard this noise only after had running engine during 20 minutes around and not at the beginning of run .
The second noise is less important but near the fuel tank cap fitter (on the wing right side) probably near carbon canister area and when I open the tank , the noise diseapear completly similar as pressure matter inside the tank
Thank's for you'r reply
Best regard's
Best regard's
Best regard's
Best regard's
Hard to read through your english but, i think i know where your headed with the post.
it sounds like your getting the famous Fuel pump failure.
https://www.6speedonline.com/forums/...fuel-pump.html
here is some info recently on the forum
Jon
Fast FWD are you referring to the venturi tubes? I had one fail on me last year.
There are a bunch of pics here. They look kind of like an octopus.
http://www.porscheturbokit.com/porsc...l-problems.asp
Jon
[IMG]file:///Users/jon/Desktop/Fuel_Pump.jpg[/IMG]
Nice links. I replaced all the rubber hose in my tank this weekend. (the straight out of the pump and the u-hose)
at 65k miles, 2002 MY, the hose was soft but no signs of splitting.
Please where did you find the rubber hose (straight and u-hose) ???
Thank's for you'r information
Best regard's
Marc
Thank's and for the "u" hose ????
Of course, one can't use the factory 'routing' without the 'U-turn" but it's just fuel line. I didn't bother taking the whole assembly completely out, so it was tricky getting the crimp clamp pliers down into the tank.
I think that standard fuel hose will fail quickly in the tank. It is not designed to be submerged. The Gates 27093 hose is submersible. It comes in 1 ft lengths. Google for suppliers. There will be several.
Jon
Jon
Correct. Standard isn't. *however* this makes me curious if the stock hose is technically 'submersible'. Mine was soft, soft enough to warrant replacement, even when I saw zero signs of it splitting.
