HID lights on gt2
HID lights on gt2
I've got one of my HID lights acting up..... will start out with the lights on, and by the time I get to my destination, one of the lights is off. I would shut them off and turn them on again, and it'll only be on for several seconds. After parking over night, the lights are again on until driven. I was wondering if anyone knew if the HID lights expire over time or over number of hours used? I've taken the lights off the car using the 5mm wrench and seems easy enough and looks fairly straight forward.... any body have tips on making this job a success? Thanks
There are several reason for a light to come on and turn off; from ballast to bulb to wiring.
Swap ballast left to right, then bulb, if issue is still there, wiring it is. I had a similar issue, turned out to be the wiring for the ground came lose inside the headlight.
Sounds like the headlight switch, or a bulb that is on its way out. From my experience, having experienced both in the past, my guess will go to the bulb being on its way out.
Try swapping your low beam bulb from one side to the other and see if the problem follows to the other side. If so, you know the culprit. I think the replacement is a D2S HID bulb.
First thing I would do switch the bulb. And if the problem persist switch the litronic control unit (see pics part# 996 631 183 00) which is also not too difficult, two torx screws and two plastic clips. Also take a good look at the pins on the mounting rack to see if one is pushed or bend....
Suggestion: If it is the control unit, it cost over $600.00 so if you do not care about a used one, look on Ebay there is some for around $100.00.....
Okay, it's not the bulb!! Ordered the ballast/control unit.... jpflip, are there particular connection patterns or order for the control unit? Thanks. You've provided more info than any of the parts guys in my little town!
I forgot, there is a plastic cap which is part of the big black electrical cable. This cap just pop out with a good tap on it....
What else could it be? The lights do work for a few minutes until something happens and cuts off the light.... Once parked, and the lights are on again. The hid light on the left just cuts off..... If you have any ideas for me to try, I'll sure like to try em.. Thanks.
You got it ! Good. It is a simple task to replace, only two torx screws and two lock tabs and you cannot make mistake for the main power plug (2 wires plug on the side of the box) which can be install only one way and you got also a ground wire. The main line on the bulb itself turn about 1/4 turn to lock and unlock. Don't hesitate to ask if you got other question and to tell us if you succeed!
I had the same problem. Sometimes the light will come on and stay on. Sometimes the light will come on then turn off later and sometimes it would turn off right away.
This guy had the same issue. He posted his fix and I posted my fix on page 4
https://www.6speedonline.com/forums/...flicker-1.html
Ballast in and lights are on!!!!! Thanks jpflip and everyone for the help! Its great to know that you can go to a forum and fix a problem rather than listening to a lot of bull from the stealerships! Thanks guys!
